Ac 101
Old 11-15-2010, 12:54 PM
  #101
KeyoRacing
KeyoRacing's Avatar
Mine just started blowing hot this week so I assume I need to look at it. If it's low is it ok to leave it that way for the winter and deal with it next spring?
Old 06-10-2012, 04:11 PM
  #102
vetteboy850
vetteboy850's Avatar
Can u post the pictures back up? its not showing up for me
Old 06-10-2012, 05:59 PM
  #103
torchredmadness
torchredmadness's Avatar
Again. Just another reason we love "The Corvette Forum". Thanks for the great info.
Old 06-10-2012, 07:03 PM
  #104
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres another good AC post that might help:
Rocco’s post http://forums.corvetteforum.com/c5-t...post1571637102
Old 06-13-2012, 09:37 AM
  #105
Raiku898
Raiku898's Avatar
+1 I would like to fix this later this week. Pictures would be really helpful.
Old 06-13-2012, 05:34 PM
  #106
Plasticfan
Plasticfan's Avatar
Pics are back up now. At least those that I still have. HTH.
Don
Old 08-12-2012, 11:12 AM
  #107
dlmiv
5th Gear
dlmiv's Avatar
I'm fairly new here and new to Corvette ownership. Your post here and several of BillCurlee's have made owning a vette so much easier and affordable. When in my teens and first married, I turned wrenches out of neccessity to keep the cars running. Though the vette is not my only means of transport, if I had to pay some one to fix every little thing that goes south on the vette or my Harleys, I would not be able to afford them. Over the years I have aquired most all the tools and what I don't have I buy. This post was outstanding! Its funny how people behind the parts counter are so quick to dazzle you with the knowledge they DON'T HAVE. I have the manifold gauge set and was told, "you don't need those any more......you don't need to know what the pressure is on the high side, just screw this can on to the low side and fill it until it reads 35lbs and your done, AC will be working fine." Ah......but I knew better then that!
Thanks again for a great post.
Life is hard.........but harder if your stupid!
Old 08-12-2012, 03:17 PM
  #108
jornahow
jornahow's Avatar
Thanks for all the effort to make this understandable. There is a problem with the Harbor Freight link, it leads to a drip irrigation kit:
http://www.harborfreight.com/cpi/cta...emnumber=92649
Just realized this is an ancient thread recently resurrected. This forum is beginning to turn into THE NIGHT OF THE LIVING THREAD
Old 08-13-2012, 02:08 AM
  #109
jdot
jdot's Avatar
There's nothing I like more than instructions how to do a job with PIX to explain. Makes it easy for us who were not born with wrenches for fingers. Thanks
Old 07-07-2013, 10:10 AM
  #110
TEXHAWK0
TEXHAWK0's Avatar
Originally Posted by Plasticfan
How do tell if my AC is short on refrigerant? This question keeps coming back so I thought I would offer up my way of checking and correcting AC charge problems. First we need to determine what the correct charge looks like because the pressures vary a great deal depending on engine speed, humidity, ambient temp and some other things. Shown below is a chart I’ve used for years with some success.
Notice that humidity has a strong effect and that all readings are taken at 2000 rpm.
For reference, here is the C5 chart from the shop manual.
Old 07-07-2013, 12:33 PM
  #111
bighank
bighank's Avatar
Default Never saw a CLAMP to puncture the side of the can - mine screws onto the top
My can tapper just screws onto the top of a R134a can not puncturing it from the side. Would think that is safer then possibly getting an explosion from poor mating surface in the side. My tapper has a wing nut piercer that punctures the metal after first screwing it onto the top of the can. Where in the world did you get that one?
Old 07-07-2013, 12:38 PM
  #112
GCG
GCG's Avatar
What's the meaning of the different zones in the first chart? How do we use it?
Old 07-18-2013, 08:04 PM
  #113
TEXHAWK0
TEXHAWK0's Avatar
I mainly posted the temperature and pressure chart at the bottom for comparison to the general chart at the beginning of this thread.
The top chart just tells you which troubleshooting procedure to use to repair a system, depending on which "zone" the high and low side pressures fall...
By the way, the outlet temperatures are with the blower on high, temp. at lowest setting, and inlet air on recirculate. I did not see that mentioned above.
Old 07-19-2013, 01:39 PM
  #114
mstromquist
mstromquist's Avatar
Received 3,866 Likes on 1,672 Posts
2015 C5 of the Year Winner
Subscribing. Will come in handy but need to get the gauges first. Thanks for posting.
Old 07-22-2013, 11:07 AM
  #115
GCG
GCG's Avatar
Thanks for your reply. This is good info!
Old 07-22-2013, 11:14 AM
  #116
GCG
GCG's Avatar
I'm in the same situation. I've been doing some research trying to find a set of gauges that's neither over the top nor garbage, but not having hands on experience in this field doesn't make the process an easy task
Do you have any recommendation?
Old 08-11-2013, 12:45 PM
  #117
KingBuscuit2112
8th Gear
KingBuscuit2112's Avatar
another a/c question... probably again. Lost power to A/C, radio, cigarette lighter. No fuses blown in console panel (passengers door) Heard under hood fuses/relays were near battery but can't find anything. Help please.
To Ac 101
Old 06-02-2016, 11:10 AM
  #118
huesmann
huesmann's Avatar
Resurrecting this thread again: if you hook up the manifold and get zero pressure on the gauges and no compressor activity--engine off or running--is it a fair assumption that the system is devoid of refrigerant?
Old 06-02-2016, 04:39 PM
  #119
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your Schrader fitting PINTAL valve is actually being depressed by the manifold hose connector, then the answer would be YES.
Just take a nail and quickly depress the pintal valve and see if there is pressure in the system.
Wear safety glasses and only let a very small amount out to test for pressure.
Normally if the gage says ZERO,, its ZERO..
Old 06-02-2016, 05:17 PM
  #120
'Shifter
Thoroughly chapped
'Shifter's Avatar
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Very nice, thanks!
Quick Reply: Ac 101
