Trunk Lid
Trunk Lid
I'm new to the C5 group with my 02 Z06 I recently picked up. My question is: Should the trunk lid pop up when the trunk release is hit? Mine barely opens about a 1/4 inch and I need to get my fingers under it. Should it pop wide open?
Hinges seem to work OK, I'm thinking the strut(s) are weak but the car only has 21K on it.
One of our posters here has made up a kit to overcome the problem. It is a spring that mounts near the latching mechanism. It works great and is really cheap. Do a search on trunk popper..... It rakes about a minute to install,
I have an 03 Zed06
I have an 03 Zed06, it is the exact same way....I think its safe to say that this is completely normal. Mine only has 15,000 and does the same thing...Here is part of the reason it does this: The corvette's cabin is extremely air tight so it doesn't really just float open like some of GM's other cars or like most other company's cars.
I like this feature it makes me believe they actually put some thought into the design of this car
Plain and simple don't waste your money on struts its normal.
Oh yeah and I would'nt use any Wd-40 because it will actually cause the struts to wear/dry out faster. Use silicone spray if you must...I stay away from this stuff unless it is truely necessary
I am curious about this spring due to the fact you already have to slam the deck lid to get it to shut. Seems pointless unless you cannot get your fingers underneath the deck lid....
Thanks everybody...........
I've been in the C3 forum for a while and the help has always been outstanding. Glad to see its the same in the C5 forum.
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
As stated above, if you don't want to add the spring, apply WD-40 to all the hinge points. Another adjustment is the two rubber strikers at each rear corner of the trunk. Turn these counter-clockwise 1/2 turn at a time to raise them slightly. Don't go too far or they will throw the alignment of the trunk off.
Received 1,227 Likes
St. Jude Donor '11
White lithium grease in a spray can sprayed in/on joints and latches worked for me
Former Vendor
St. Jude Donor '08
Here ya' go..
www.C5trunkpopper.com
For great product.
I have also installed the trunk popper spring and think it is a great product.
