How to check differential fluid?
Old 09-23-2007, 03:11 PM
ransvett
ransvett's Avatar
Default How to check differential fluid?
Is there a way I can check the level of the differential fluid I got a small leak and want to check the fluid i dont have a lift or ramps??
Old 09-23-2007, 03:27 PM
DeeGee
DeeGee's Avatar
Heres a thread that shows how to change the diff fluid. It'd be tricky to get at with the car on the ground.
http://forums.corvetteforum.com/show...ighlight=fluid
Old 09-23-2007, 03:32 PM
ransvett
ransvett's Avatar
thank you but i dont want to change it now i just want to check the level is this possible?
Old 09-23-2007, 03:41 PM
DeeGee
DeeGee's Avatar
I'm on shakey ground and you may want to post in the Tech Forum but I seem to remember that you top up until you get fluid coming from the fill hole. Post on Tech and there are smart guys who will answer.
BTW is the leak from the seal? If so you might want to read this TSB
http://www.corvetteactioncenter.com/...over+Flange%29
Old 09-23-2007, 03:45 PM
Jim2003
Jim2003's Avatar
I just changed my fluid. The fill hole is up higher to on the backside. Undo it and stick your finger straight in. You should just barely touch the fluid level. The fluid should be just at the bottom of the fill hole. The car must be level to do this check.
It takes longer to jack the car up and put the 4 jack stands under it than it does to check the fluid level.
Old 09-23-2007, 04:00 PM
DeeGee
DeeGee's Avatar
Old 09-23-2007, 04:26 PM
ransvett
ransvett's Avatar
its a 02 zo6 sorry i didnt mention that ,is the fill hole in the same place? anyone happen to have a picture of where exactly it is??
Old 09-23-2007, 05:30 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Ummm.......please read post #2. K?
Old 09-23-2007, 05:47 PM
moserbe
Support Corvetteforum!
moserbe's Avatar
At the rear bottom right just below the label.
Old 09-23-2007, 05:59 PM
csexton
csexton's Avatar
Chuck
Old 09-23-2007, 09:49 PM
ransvett
ransvett's Avatar
Excellent pic moserbe thank you
Old 09-23-2007, 10:13 PM
moserbe
moserbe's Avatar
Glad that I could help.
To How to check differential fluid?
Quick Reply: How to check differential fluid?
