shifter feels wierd when I put it in 3rd gear while driving
While I am shifting into 3rd gear (from 2nd) while driving, a lot of the times it feels like the shifter doesn't slide into gear as smoothly as the other gears. I had the dealer replace the 3rd gear syncro but it is still doing it. I also noticed it slides in much smoother at high RPM....
Any idea what the problem could be?
Thanks!
Thanks!
My 02 did it and my 04 does too! I had them both to the dealers and complained about a "crunch" feel from 2nd to 3rd...of course "nothing is wrong" I do find that when everything is up to temp, or the weather is hot it is not doing it.
Oh ok.... so i guess it's normal in these cars then? I feel much better now.
Yeah seems like it's normal with all these responses. I know I could make the "crunch" go away if I shift into 3rd at high RPM... not really sure why it does that. Everyone also seems to experience the once in a while issue with shifting into 1st or reverse (requiring that you momentarily put it into another gear before trying again).
