Should I put carpet under the tires for winter storage?
Guest
Posts: n/a
No!
But if you are really worried put it on some jackstands for the winter! Just a thought!
Thanks,matt
Thanks,matt
Today's tires will not flatspot. I park my car on four pieces of plywood. The reason to park the tires on a piece of plywood, or carpet, is to keep moisture from leaching out of the concrete into the rubber of the tire. Also, I just leave regular air pressure in the tires when I put the car into storage. I've never had a tire flatspot on my Corvette and this is Minnesota where the cars are in storage for several months. I certainly wouldn't use jackstands, either. You remove loads from components of the chassis that are best left preloaded.
Ed
Ed
I put heating pads under each tire -- nothing's too good for my Vette!
Received 19,284 Likes
'20-'21-'22-'23-'24
I put carpet under mine just to keep them off the cold concrete.
