have vin number need options
Old 01-06-2008, 01:39 PM
jayzze
jayzze's Avatar
Default have vin number need options
i am doing a poster and need help with options and codes the vin number is 1G1YY32G525111343 any help appreicated thanks
Old 01-06-2008, 01:50 PM
blacksedan87
Support Corvetteforum!
blacksedan87's Avatar
Location: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The VIN won't give you much unless you have someone run the VIN through GMVIS. Several members here have access to that system and could provide you with service and origination history, along with the list of RPO's (regular production options).
If the RPO list is what you are after, you can refer to the sticker inside the glove box door ('99 or newer) or under the left rear cargo compartment lid ('97 or '98). You can then decode the RPO list by referring to this link - click here.
Old 01-06-2008, 02:19 PM
Sponge Vette
Sponge Vette's Avatar
St. Jude Contributor
This might help.
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2002 CORVETTE CONVERTIBLE Warranty Start Date : 11/07/2001
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : MAROONE CHEVROLET OF FORT LAUDERDALE
1300 N FEDERAL HWY
FORT LAUDERDALE , FL 33304-1428
(954) 567-7000
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/21/2006 038167 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 20137 miles
05/01/2006 033914 # V1144 - 04006 - INSTALL HARNESS KIT, REPROGRAM AND PERFORM FUNCTIO 20116 miles
06/07/2004 238715 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 12000 miles
06/02/2004 432958 # L1224 - FUEL TANK FUEL PUMP MODULE REPLACEMENT - RIGHT SIDE 12400 miles
06/02/2004 432958 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 12400 miles
07/28/2003 409913 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 5494 miles
07/17/2003 064328 # A2681 - LID, STOWAGE - COLOR/CLEAR COAT 4263 miles
07/17/2003 064328 # B4000 - FRONT SIDE DOOR ADJUSTMENT - RIGHT SIDE 4263 miles
07/17/2003 064328 # B1880 - FENDER, FRONT - RIGHT - ALIGN 4263 miles
10/24/2001 A11343 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1660 kg (3660 lb) Order Number : DPRK6M
Build Date : 10/24/2001 Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE LOW EMISSION VEHICLE GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
R9Z - POMS EXPEDITE - SOLD ORDERS SLL - SOLD ORDERS
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SC - CORVETTE CONVERTIBLE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
41T - T0P-BLACK 79U - MILLENNIUM YELLOW W/TINT COAT
Old 01-06-2008, 03:11 PM
blacksedan87
This is exactly what I was talking about - way to go S.V.!
Old 01-06-2008, 03:52 PM
snowgoer
snowgoer's Avatar
Can I get one of those GMVIS for my Vette? If so, here is the VIN 1G1YY32G3X5100879. That actually shows the service history also. Very cool
Old 01-06-2008, 04:23 PM
Sponge Vette
VEHICLE INFORMATION
Merchandising Model : 1YY67 Warranty Start Date : 08/10/1998
Delivering Dealer : UFTRING CHEVROLET-OLDSMOBILE, INC.
PO BOX 267
WASHINGTON , IL 61571-0267
(309) 444-3151
CLAIM HISTORY
08/01/2007 351970 B F1515 - HALFSHAFT, REAR DRIVE - REAR - BOTH - REPLACE 16283 miles
06/01/2005 322550 J V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 8585 miles
04/23/2001 239116 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 5315 miles
04/23/2001 239116 # E0032 - CAP, WHEEL CENTER - FRONT - REPLACE 5315 miles
08/24/2000 225554 # N6638 - WIRING AND/OR CONNECTOR - WIPER/WASHER SYSTEM - REPAIR OR 3515 miles
08/24/2000 225554 # B7241 - BEZEL - HEADLAMP - LEFT - REPLACE 3515 miles
08/24/2000 225554 # B7240 - BEZEL - HEADLAMP - RIGHT - REPLACE 3515 miles
08/21/2000 225297 # E7200 - IGNITION LOCK CYLINDER REPLACEMENT 3493 miles
08/21/2000 225297 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 3493 miles
08/21/2000 225297 # N0110 - BATTERY - ONE - REPLACE 3493 miles
08/21/2000 225297 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 3493 miles
09/09/1999 204824 # B3590 - COVER ASSEMBLY, FOLDING TOP - R&R OR REPLACE 2779 miles
09/09/1999 204824 # C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 2779 miles
06/09/1999 103030 # N6270 - ENGINE WRG REP 1743 miles
06/09/1999 103030 # K1080 - SEAL AND/OR BOOT, FLOOR MOUNTED GEARSHIFT - REPLACE 1743 miles
06/09/1999 103030 # J4640 - MOTOR ASSEMBLY, STARTER - REPLACE 1743 miles
09/08/1998 087654 # C2510 - PAD, INSTRUMENT PANEL COVER ASSEMBLY - REPLACE 1009 miles
08/10/1998 093407 # Z6999 - PDI RELATED FLUID ADDS 7 miles
07/30/1998 A00879 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1680 kg (3704 lb) Order Number : 920C78
Build Date : 07/29/1998 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
B84 CJ2
C05 DL5
DL8 FE3
FE9 GU6
IL3 JL9
K63 LS1
MM6 MN6
NF2 NK4
N37 QD4
R8Q R9Z
T96 UL0
UV6 UZ6
U1S U52
U75 VM3
V49 V73
XGG YGH
Z51 1AZ
1SA 19I
193 23U
41T
for some reason all 1999 Corvettes on options, only show the codes click this link and match the codes with a description LINK to OPTIONS
Old 01-06-2008, 04:25 PM
snowgoer
snowgoer's Avatar
Thank you
Old 01-06-2008, 04:37 PM
Drew K.
Drew K.'s Avatar
How about 1G1YY12S825125147? TIA
Old 01-06-2008, 04:45 PM
EricD701
EricD701's Avatar
who didn't see this comming
Old 01-06-2008, 05:00 PM
Sponge Vette
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2002 CORVETTE Z06 Warranty Start Date : 04/20/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : HOSKINS CHEVROLET, INC.
PO BOX 175
ELK GROVE VILLAGE , IL 60009-0175
(847) 439-0900
CLAIM HISTORY
02/06/2006 276911 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 25085 miles
04/19/2005 267604 # J6090 - VALVE, SAI CHECK - RIGHT - REPLACE 19790 miles
08/11/2004 258623 # N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 14970 miles
08/11/2004 258623 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 14970 miles
08/11/2004 258623 # N4921 - MODULE, LOCAL INTERFACE UNIT - DOOR - LEFT - REPLACE 14970 miles
08/11/2004 258623 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 14970 miles
05/17/2004 254271 # L1020 - CAP, FUEL TANK - REPLACE 13708 miles
04/20/2004 252781 # N3231 - ACTUATOR ASSEMBLY - HEADLAMP - LEFT - REPLACE 13053 miles
03/15/2002 A25147 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1614 kg (3559 lb) Order Number : DXQGPR
Build Date : 03/15/2002 Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE4 - RIDE & HANDLING SUSPENSION SYSTEM
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
P12 - CAST ALUMINUM WHEEL SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U73 - FIXED MAST ANTENNA
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFW - FRONT TIRE-P265/40R17
YFU - REAR TIRE-P295/35R18 1SA - CORVETTE Z06 BASE EQUIPMENT GROUP
19I - BLACK INTERIOR TRIM 194 - Z06 INTERIOR - BLACK
21U - ELECTRON BLUE METALLIC
Old 01-06-2008, 05:02 PM
Drew K.
Drew K.'s Avatar
Originally Posted by Sponge Vette
VEHICLE INFORMATION
Thanks!
Old 09-19-2008, 08:03 PM
Mojo 97 Vett
Mojo 97 Vett's Avatar
may I please have one on my vert as well 1G1YY32G6W5123183 . Thank you
Old 09-19-2008, 09:50 PM
Nightstick
Nightstick's Avatar
Oh Snap!! Do me, do me
1G1YY22G635120516 I just got mine and the dealer wouldn't tell me anything. You da man!
Old 09-19-2008, 10:01 PM
Blue 92
Blue 92's Avatar
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I really don't want to pile on but I'd also love to know what has been done.
1G1YY32GX35102915
Thanks.
Old 10-19-2008, 09:35 AM
DT
DT's Avatar
It's too bad GM jsut doesn't open this as a public accessible web service. Even just limiting it to the CPO's would be outstanding. I'm shopping right now and I know the listings are a little generic.
Old 09-18-2009, 01:08 PM
sal826
sal826's Avatar
I hate to ask this, but can someone run this VIN through GMVIS for me?
VIN # 1G1YY24U555105639
TIA
Old 09-18-2009, 01:18 PM
AZ Vert
AZ Vert's Avatar
At the risk of being rude and asking too much, which we'vr already done, how about:
1G1YY32G145130376
Thanks.
To have vin number need options
Old 09-18-2009, 01:26 PM
lil vette
lil vette's Avatar
...You may have to quit your day job
ROFL
Old 04-17-2010, 09:22 PM
hdboomer
hdboomer's Avatar
Default Help with vin 1G1YY32G115109524
Please check history for this vin, new poster, corvettes in the past 3 1962's red, black and white, all hard topped.. 1 1964 silver buying a 2001. pewter
1G1YY32G115109524
Thank you very much
Old 04-17-2010, 09:45 PM
Sponge Vette
1G1YY32G115109524
Thank you very much
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2001 CORVETTE CONVERTIBLE Warranty Start Date : 10/31/2000
Delivering Dealer : MEMERING MOTORPLEX INC.
1949 HART ST
VINCENNES , IN 47591-5519
(812) 882-5367
Open Recall:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004
CLAIM HISTORY
02/08/2002 066180 # N0912 - EXTERIOR LAMP BULB SOCKET REPLACEMENT 7354 miles
07/10/2001 064381 # A1241 - MIRROR, OUTSIDE REARVIEW - COLOR/CLEAR COAT - LEFT SIDE 4647 miles
11/24/2000 103966 # N0850 - FRONT FOG LAMP BULB REPLACEMENT 250 miles
10/09/2000 A09524 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1658 kg (3656 lb) Order Number : CRSZ8J
Build Date : 10/09/2000
OPTION CODES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL4 - ACTIVE HANDLING SYSTEM JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
QG1 - PAINTED ALUMINUM WHEEL T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - COMPACT 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AY - STOCK ORDERS PROC OPTION
1SB - CORVETTE CONVERTIBLE PREFERRED EQUIPMENT GROUP 1: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV 11U - LT PEWTER METALLIC
41T - T0P-BLACK
Quick Reply: have vin number need options
