Code B-0363 H
Old 01-29-2008, 08:02 PM
bobsride
bobsride's Avatar
Default Code B-0363 H
I ran my on board system check and came up with this code. I know it is for Left Actuator Feedback Open. The heat and A/C seems to work fine. Is this some thing that needs repairs, intermittent as it has a H on the end for history.
Your help and advice is appreciated is this matter
Bobsride
Old 01-29-2008, 11:26 PM
Junkman2008
Junkman2008's Avatar
Hey Bob, since it's a history reading there's no telling when it happened. It also could have been a fluke thing and if you clear it, it may never show up again. I'd clear it and then check for the next 2 weeks to see if it comes back. Just make sure you're using your car a lot in order to give it a chance to re-show. FYI, you may get more responses if you fill out your profile.
Old 01-30-2008, 09:03 AM
c5streak
c5streak's Avatar
That one shows up on a regular basis on mine. Everything works fine, so I'm not messing with it. Really don't want GM tearing my dash out to chase it.
To Code B-0363 H
Quick Reply: Code B-0363 H
