New Battery?
Old 01-30-2008, 04:42 PM
johnathanrn
johnathanrn's Avatar
Default New Battery?
Hi all. I was wondering if changing the battery on my c5 1997 to a lightweight battery would be worth the money? what do you think?
Old 01-30-2008, 05:05 PM
jrose7004
jrose7004's Avatar
Received 1,672 Likes on 1,295 Posts
I wouldn't think that it would be worth the trouble and expense just to save what little weight you would save.
Old 01-30-2008, 05:10 PM
WetteVette
WetteVette's Avatar
Depends on what you mean by "lightweight".
As long as it has enough (correct) cold cranking amps (CCA), then you should be OK.
Personally, I would stick with a good name-brand battery. There have been hundreds of battery threads here on the Forum. Do a search.
Old 01-30-2008, 05:49 PM
GRUNIE
GRUNIE's Avatar
Also a gel type (no leaking)
Old 01-30-2008, 06:36 PM
C5R USA
Support Corvetteforum!
C5R USA's Avatar
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Old 01-30-2008, 06:40 PM
jacks996
Jacks996
jacks996's Avatar
Cruise-In VIII Veteran
optima red top and you will never have a problem
Old 01-30-2008, 07:41 PM
LRD VDR
LRD VDR's Avatar
Surely you are joking?
Shahram
Old 01-30-2008, 07:56 PM
silverbullit99
silverbullit99's Avatar
Buy the original Delco, It is much improved. And if you want to feel safer buy a battery mat to place under the battery should it ever leak.
Old 01-30-2008, 08:46 PM
2K14C7
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I couldn't imagine any battery saving enough weight to make any performance difference.
Old 01-30-2008, 09:13 PM
1998whitecoupe-a4
1998whitecoupe-a4's Avatar
well so called "racing" batteries are about 15 lbs to 16 lbs, and can produce enough CCA's to crank a Vette engine.
"Stock" batteries are about 45 lbs or slightly higher so you do save on weight.
Costs range from 160.00 to 350.00+
To New Battery?
Quick Reply: New Battery?
