Which stock wheel is lightest weight??
Does anyone know the weight of each of these rims without tires, or which one weighs the least?
stock Magnesium wheels:
stock C5 Z06 wheels:
stock C6 wheels:
stock C6 Z06 wheels:
Or does anyone know where I can find out? I am only interested in stock wheels as a replacement for the wagon wheels. Thanks fellas...
stock C6 wheels:
Pretty sure sotck magnesium, check the weight and measures sticky at the top of the page
Ok, so its the Magnesium
So after doing research, these are the lightest tires I could find as a set. Anyone used these? If so what are your thoughts?
Continental ContiExtremeContact Specs
245/45WR17 24 lbs
275/40WR18 25 lbs
UTQG: 400 AA A
245/45WR17 24 lbs
275/40WR18 25 lbs
UTQG: 400 AA A
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Those extreme contact is good tire. I have used contact sport 2 and they are good tires for the price and those extreme's are better tires.
But don't trust on the weight is listed by tirerack
-Mike
-Mike
C5 Z06 20.5 lbs frt and 22 rear and C6Z 22 frt and 26 rear. Don't know the stock magnesium weight but I expect they are heavier than the C5Z wheels which are featherweights compared to most.
The Z wheels are wider than the standard Vette wheels so you can put bigger rubber on, esp the huge C6 Z rims. Light weight is nice but the more rubber you have the better you stick right.
The stock C6 wheels are extremely expensive where the C5Z wheels are plentiful used.
Received 1,675 Likes
No question, magnesium.
From the sticky
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon - Src
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon - Src
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium - Src
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium - Src
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish - Src
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps - Src
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish - Src
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
24 lbs, 18x10.5 - 00+ repro high polish - Src
28 lbs, front; 32 lbs, rear - Z06 chrome repro - Src
23 lbs, front; 26 lbs, rear - Z06 chrome repro - Src
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished - Src
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear - PWO - Src
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center - Src
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center - Src
24/25 lbs - Z07 wheel weight, front - Src
28 lbs - Z07 wheel weight, rear - Src
