Front license plate cover removal.
Old 02-08-2008, 11:39 AM
LAYNLOW
LAYNLOW's Avatar
Default Front license plate cover removal.
How do you remove the front plate cover?
Thanks!
Old 02-08-2008, 11:41 AM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I believe there is 2 screws at the bottom of the cover.
Old 02-08-2008, 11:42 AM
427435's Avatar
That's correct---they may be a little hard to see if the cover has deformed down.
LAYNLOW
LAYNLOW's Avatar
Where do you access them from?
Thanks!
Old 02-08-2008, 01:51 PM
Twospeed
Twospeed's Avatar
Directly from the front, and bottom of the cover, the screws are about two inches in from each side and they are small phillips head screws. That front cover is some what flexable ( at least in Florida temperatures ) so don't worry if you have to angle the screw driver a little. Take the two screws out and swing the bottom of the plate cover out and up.
Old 02-08-2008, 02:18 PM
LAYNLOW
LAYNLOW's Avatar
Thank you!!
Old 02-08-2008, 05:14 PM
04 commemorative
04 commemorative's Avatar
St. Jude Donor '17
I use a thin shafted philips, I also put the Licence on for inspection this year and then put the cover on over it with velcro in case I ever get busted. The top has tabs that slide in under the nose and it seems to be staying on very well! Velcro on the bottom only.
Old 02-08-2008, 06:30 PM
dmoore
dmoore's Avatar
I had to lay down in front of the car to get to the screws, they are under there you just have to look closely!
Old 02-08-2008, 07:35 PM
LAYNLOW
LAYNLOW's Avatar
Took it off when I got home from work, piece of cake.
Thanks!
To Front license plate cover removal.
Quick Reply: Front license plate cover removal.
