Extra 3 wire plug in harness/r.pass footwell?
Old 03-25-2008, 09:34 PM
LT1GMC
LT1GMC's Avatar
Default Extra 3 wire plug in harness/r.pass footwell?
In my 03 Z06, there is an unused plug taped to the harness by the right foot of the passenger. I can't find it in the service manual. It has a green wire, orange wire and black/white tracer wire. It is NOT the accessory harness which is on the left side. It appears as it might be the supply to the power antenna(doesn't have pink, but pink and green can do the same thing in the radio wiring according to the manual). It might be the plug for the antenna amplifier used in the coupe in some years(windshield antenna).
Anyone know? I would like to use it for the power antenna I am installing, but wanted to check here first. Thanks
Old 03-25-2008, 09:39 PM
Vega$Vette
Vega$Vette's Avatar
Received 2,112 Likes on 986 Posts
It's just an extra switched (ignition) and unswitched power and ground. You can use it.
Old 03-25-2008, 10:36 PM
LT1GMC
LT1GMC's Avatar
Found it in the service manual, finally, it IS the power antenna plug, for the convertible, so its the perfect place for my antenna upgrade.
To Extra 3 wire plug in harness/r.pass footwell?
Quick Reply: Extra 3 wire plug in harness/r.pass footwell?
