C5 Door Window Seal
C5 Door Window Seal
I am replacing the drivers door window and have discovered that the inner window felt wiper seal is both worn and also missing part of the seal. I have looked at the corvette catalogs along with online dealers and noone seems to carry the inner seal for the C5. I have replaced the outer (I have a tip if you are going to replace yours - remove the screw at the front of the door on the seal and "slide" the whole seal to the rear). Anyone out there who has dealth with this or know of someone who might have a replacement? I have checked with the dealer and it is part of the door panel (at a price well over $400). So that option is out. Tks and hope to hear from someone.
c5 Door window seal
Hi 98 vette,
This salvage yard usually has nice items.Located in Bristol,Pa. [url]http://stores.ebay.com/Fparts_USED-Corvette-Parts-97-04_W0QQcolZ2Q
I hope this helps you.
robsc501
robsc501
