How many miles do you have on your aftermarket clutch?
Old 06-11-2008, 12:19 AM
Mark2ooo
Mark2ooo's Avatar
Default How many miles do you have on your aftermarket clutch?
I have 90000 miles on my stock clutch. Has anyone had this kind of luck with their aftermarket clutch? How many miles do you have on your aftermarket clutch?
Old 06-11-2008, 01:46 AM
vettegator005
vettegator005's Avatar
Old 06-11-2008, 02:01 AM
Ricky218
Ricky218's Avatar
Old 06-11-2008, 06:22 AM
kww
kww's Avatar
At 39,000 miles I replaced my clutch. Although showing no problems with the extra 75 horsepower I had ECS put in a Textralia Exo-Skel twin disc when I went the full Novi 2000 supercharger route. I've put on about 1100 miles since with no problems. Now my only problem is the back tires seem to need replacing more often.
Old 06-11-2008, 07:21 AM
Corvette Don
Corvette Don's Avatar
a little more than 4500 on my CF
Old 06-11-2008, 12:15 PM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,099 Likes on 810 Posts
If you have that many miles on a stocker just order the C5 Z setup and be done with it, no need to spend more unless you are changing your hp and then a more expensive one will be ok to upgrade to
Old 06-11-2008, 12:16 PM
JohnTheStigGalt
JohnTheStigGalt's Avatar
Originally Posted by peter pan
If you have that many miles on a stocker just order the C6 Z setup and be done with it, no need to spend more unless you are changing your hp and then a more expensive one will be ok to upgrade to
Fixed it for ya!
Old 06-11-2008, 01:18 PM
chrisj
chrisj's Avatar
St. Jude Donor '12
I have about 10,000 on my centerforce. Works like a champ. I put about 70,000 on the stock clutch. When it went, it was time to upgrade so the clutch could handle the cam.....
chris
Old 06-11-2008, 05:52 PM
Robls6
Robls6's Avatar
I have over 15,000 on my Mcleod dual disc with no problems at all.
To How many miles do you have on your aftermarket clutch?
Quick Reply: How many miles do you have on your aftermarket clutch?
