Pulled the code this morning - P0440
Well, I pulled the code this morning. It came up P0440. I know, before everyone tells me to check the gas cap, it is on tight. Any ideas what else it could be?
Hers a little info on the code from the OBD-II web site.
P0440 OBD-II Trouble Code
Technical DescriptionEvaporative Emission Control System Malfunction
What does that mean?This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
SymptomsYou likely won't notice any drivability problems.
CausesA code P0440 could mean one or more of the following has happened:
The gas cap is not installed or working properly
The purge solenoid has failed
The canister is plugged and not working properly
Possible SolutionsWith a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
Inspect the EVAP system for cuts/holes in tubes/hoses
Inspect for damaged or disconnected hoses around the Evap purge solenoid
Check and/or replace the sensor
Check and/or replace the purge valve
Have a professional use a smoke machine to detect leaks
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
I see you have an 03 most common problem is the evap purge solenoid located on drivers side behind the intake manifold.but you need to remove the manifold to get to it approx 2 hrs start to finish
If not theres some great advice here.
Thanks guys for all the help and advice. I will be back home tomorrow so I will check the gas cap again for a good seal. I cleared the code so I will take it for a ride to see if it comes back.
Thanks again
Thanks again
Hi There,
A quick way to troubleshoot the gas cap.Take some duct tape, tape all around the base of the cap & trim off the excess carefully.Then reinstall the cap.
This will make a good seal for a temporary test.If the dic code disappears, then buy a new gas cap gasket. Do not leave the tape on more than a hour.It will melt.If you have a thin sheet of cork gasket material this will seal also.
robsc501
robsc501
