Optima Battery ???
Old 11-08-2008, 06:25 AM
killain
Support Corvetteforum!
killain's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
FWIW, I have a 2003 50th AE and i have a Optima Red Top in it, The number is 75/25 - SC75U and it came with a three year warranty? Been working OK for the last two years.
Old 11-08-2008, 09:42 AM
minitech
minitech's Avatar
I'm not bashing Optima but here are some facts:
Optima has by far lower performance ratings than non-Optima batteries. Just stand in the store and look at the difference.
They are made differently with a spiral gel design and the benefit is they can work in any angle and with changing angles like IN A BOAT.
They have some less ability to leak. Leaking is a sensitive issue with the C5 because the battery is above the computer. Older stock C5 batteries on early C5s did leak sometimes. ANY modern battery is not likely to leak.
Some people like the way they look. Those who know what they are talking about know you made a poor choice.
If you are running a high end audio system get the highest rated battery you can find (and it will not be an Optima.)
No need at all for a deep cycle battery for an audio system unless you plan on running the audio system with the car off and running the battery dead. Deep cycle can tolerate that but again, who would do that?
Old 11-08-2008, 10:54 AM
hotwheels57
hotwheels57's Avatar
I have been using OPTIMA batteries in vehicles since before they were even available to the general public. Our fleet in AZ and a similar fleet in CO both tested the batteries for the manufacturer for summer heat and winter cold.
I've never had one fail in fleet use or personal use. My longest lasting red top was still going strong at seven years when I sold that vehicle. The buyer was still using the same red top two years later.
I have OPTIMA red tops in all of our current vehicles except our '07 Silverado. When the oem battery in that needs to be replaced, it'll get an OPTIMA.
It's the owners car to do with as the owner pleases...
COSTCO 75/35 in my '04 Z16 since the day I bought it.
Old 01-12-2009, 02:30 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
No issues with mounting it with the factory hold down ?
Thanks !
Toque
Old 01-12-2009, 08:17 PM
Allzwell
Allzwell's Avatar
Cruise-In VIII Veteran
Thanks !
Toque
No issue with the original hold down here. It is a bit particular about how it is clamped but once you get it secured you're good to go.
Mine sits for weeks without a battery tender and no problems
Old 01-12-2009, 08:52 PM
08 ATOMIC-Z
08 ATOMIC-Z's Avatar
SAVE your self some heartache and buy a DieHard Automotive Battery, Platinum P-3 - Group Size 75/86DT. It will never leak and will never go dead for two years guaranteed. Yes it doesn't have RED TOP but it wont leave you stranded or leak on your PCM.
Old 01-12-2009, 08:57 PM
Choreo
Choreo's Avatar
Been running a Red Top for the past 5 years on my DD - no problems here.
If the car has to sit more than a day, I put the CTEK on it.
One other thing I always do... when I have to take it to the dealership (as in two months ago for a 4 week motor swap) - the first thing I did was talk to the mechanic and I disconnected the battery myself once it was in the bay and told them that if they had to reconnect it, to disconnect it as soon as they were done testing since if a Red Top ever drains it will probably never come back all the way.
Old 01-12-2009, 09:59 PM
c5BlackBeauty
Corvette C5 Enthusiast
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by chris holmes
I've had 3 Yellow tops over the past few years. I'm sure other people will disagree, but they've been nothing to be a pain in the *** for me. I recently moved to a lightweight Braille 3121, and it's been working fine. Same price and it weights half as much.
I agree. I drank the Optima Kool Aid and ended up buying a Yellow Top. After repeated problems I moved to a Sears Platnium......excellent battery and no problems.
Quick Reply: Optima Battery ???
