Help with some mods
Old 11-21-2008, 11:44 AM
snake0824
snake0824's Avatar
Default Help with some mods
Ok i have 04 c5 stock .What would be the first mod to do for hp for the money to start with.i know once you start mods its hard to stop .i just wont to take it easy if i can .some help would be great
Old 11-21-2008, 11:49 AM
Wop1
Wop1's Avatar
A set of long tube headers with hi flo cats, X pipe and air intake, along with a good dyno tune from a reputable tuner should give you the most bang for the buck. This should not be much more than $2500 installed.
Old 11-21-2008, 11:52 AM
snake0824
snake0824's Avatar
How much hp would i gain with that set up???????
Old 11-21-2008, 01:37 PM
Wop1
Wop1's Avatar
My car was done incrementally, documenting what each step produced. I got about 50 HP from this. BTW, LG Streets are what I put on mine, see sig for the rest. The tuner is really the key to getting the power and driveability you want. Also make sure you have the installer upgrade the clamps if you go with the Streets. LG makes a great product but these are budget priced and don't come with the wider clamps, leading to leakage. I replaced all with the wide stainless clamps and that solved the leakage issue.
Old 11-21-2008, 03:15 PM
LDB C5
LDB C5's Avatar
It all depends on what you want from the car. Do you want (need) more HP or better seat of the pants acceleration?
If you are lookin to wake the car up, I would go with a different rear end maybe 3.42 if you have an A4 or 3.90s if you have an MN6.
Old 11-21-2008, 03:20 PM
happa
happa's Avatar
Id say, a nice intake and a cat-back exhaust. Then save a little more buy Long Tubes and get a tune Good Luck trying to stop the Mod Bug
Old 11-21-2008, 03:25 PM
steve8
steve8's Avatar
Some good advice above.
Cam, SC.
What are you looking to attain? And the age old adage of you can go as fast as you want to spend.
Current transmission and rear end would be good to know.
Old 11-21-2008, 04:42 PM
snake0824
snake0824's Avatar
Its a base model c5 auto what a 2.73 rears.Just looking for some extra hp without heads and cam.Thanks
Old 11-21-2008, 04:59 PM
sneakelman
sneakelman's Avatar
St. Jude Donor '08-'09
Performance hood seal....
OK, OK.....headers, cat-back, and tune. Best bang for buck.
Old 11-21-2008, 08:18 PM
dobewillie
dobewillie's Avatar
lol didn't take long for the performance hood seal to pop up
Old 11-21-2008, 09:10 PM
Indy
Indy's Avatar
Racing stripes add about 25 hp to the rear wheels...
Intake and Exhaust are the easiest to install and make a definite difference! Cheers, Indy.
Old 11-21-2008, 11:00 PM
motogib1
motogib1's Avatar
With the headers and some 3.42 gears you would take a full sec of you 1/4 mile ET. The headers and tune could give you up to 50 rwhp. Plus the sound is much improved. You will love it.
Old 11-21-2008, 11:28 PM
rob-cyn
rob-cyn's Avatar
So far, I ave done a Vararam Intake and Corsa Pace Car cat back exhaust. Very happy with the results and love the sound of the Corsa exhaust. Next I will do the long tube headers, x-pipe and a tune.
Old 11-22-2008, 12:02 AM
Riley P
Riley P's Avatar
Cold air intake, exhaust, tune. I have a Vararam, Borlas, and a tune which I believe has netted me about 50hp.
Old 11-22-2008, 12:16 AM
Thickraybans
Thickraybans's Avatar
Best bang for the buck.First gears,good tires,and spray a 100-150 shot with a good tune.Then start saving for a high stall converter.
To Help with some mods
Quick Reply: Help with some mods
