Battery/charging probs?
Hi,
I was wondering about battery/charging problems.
I just replaced my battery again, free because it was less than a year, from the battery store, because if I let my vette sit for more than a week, it is deader than a doornail.
So, with the new battery, it seems to hold the charge longer but even after, say ten days, it does still turn over a little slow.
My question is, is there maybe a recharging problem in the car, or...is there something constantly drawing on it, which is normal for vettes?
Sure would appreciate some info on this. I do have a trickle charger but I dont put it on unless I am storing it for the winter, which hasnt happened yet.
Thanks,
Vettenlady
Thanks,
Vettenlady
yes this is a common problem , i keep a battery tender hooked up to mine at all times , you can get one from forum vendor chip ( willfulone ) CCA , chips a great guy and will take care of you
oak
oak
Corvette C5 Enthusiast
Lots of posts on this issue if you do a Search. C5's are battery hungry so even having her sit a few days without use may create a drain. Best advice is to get a device to keep the battery charged. Battery Tender is one choice. Also, Chip of CCA has a new one out that I just purchased, which is superior IMHO to the Battery Tender.
C5's are notorious for draining batteries when the car sits for a while. I bought one of the CTEK 3300 smart chargers from Chip. If my car sits for even a couple of days - I plug it in. The smart chargers will not overcharge the battery, where a trickle charger will keep charging the battery even after it's reached full charge.
Battery Tenders are another brand of smart chargers.....
with the comments and I fitted an Optima Yellow Top and hook it up to a tender when its going to sit for any length of time. A battery Tender will solve the immediate problem in that it'll keep it topped off but it may be masking another problem. AGM batteries such as the Red Top wont leak but they don't like being discharged. Once they are fully discharged it may be impossible to recharge them.
I'd still be worried if a new battery is draining so quickly. A fully charged battery should last way longer than a week.
What I'd suggest is to try to find out if you have a drain. Sometimes the seat switches can stick open or you may have an add on device thats causing a draw.
Bill Curlee posted this set up to check for current draw. Check out post #9
http://forums.corvetteforum.com/c5-t...979-drain.html
If you find theres more draw than you should see you can pull fuses to track down the offender.
My car was in transit from the States for about 8 weeks. Got a brand new battery fitted before it left. When it arrived - dead as a doornail.
Completely sulphated and wouldnt take a charge.
Could jump the car but even after 30 minutes running wouldnt move off and died.
Just goes to show you need to drive them.
Battery tender now in use.!!!
Definitely agree with the driving bit
