Strange Drivers Seat Problem (Not Seat Rock)
So i have a strange problem with my drivers seat when i start my car. When i get in and start it the seat moves back, not like its loose on the rails, but as if you were pushing the side button to move the seat back electrically. it moves like 2-3 inches sometimes and its really annoying bc i always have to move it up again...ive tried to set the seat memory to the position i want and it still moves the seat back to something completely different than the position ive set in the memory...
does anyone know whats wrong here or have had a similar problem?? its REALLY annoying
Thanks guys
Evan
Thanks guys
Evan
Have you tried resynching your key fob to the appropriate memory setting - fob #1 to memory #1 and fob #2 to memory #2? The computer keys on the fob you use to unlock the car with and activates that memory setting.
how do you sync it up? does it automatically sync up to that key when you start the car? ive always used the same key. plus it doesnt always happen...but its starting to get worse
Anyone else?
Possible, Frozenfire. However, the A/C condensate drain is a single, small elbow above the BCM which is situated in the passenger's footwell next to the inside fuse box. Pull the passenger foot rest cover off and you'll see them there.
