Brackets are the same but the bushings are different.
The z06 bars are thicker so you need the correct bushings
One word of caution. Be careful when threading in the bolts for the sway bar brackets. Very easy to cross thread the aluminum. Also, the torque values are different for the bolt vs.the nuts that attach the brackets. The top bolt is 49 foot pounds the lower nut is 70 foot pounds.
