Aftermarket Radio Will Not Turn On
Hey Guys,
I just bought and aftermarket radio and have the bose adapter but cant get the radio to turn on. The sticky says that when the stock radio is out it wont send a signal to the BCM to turn on the new radio and you need to tap into the fuse #22 under the passenger fuse box. How do I do this! I am very new at electrical work. Some one please help me I dropped 400 on all this radio stuff and cant get it to work!
Don't know much about the radio stuff,,but I can help you find the fuse . The fuse box for the BCM is under a removable floor panel at the front of the passenger foot well!! The diagram of the fuse #s is on the inside of the fuse box lid. Hope this helps!!
as already posted either tap the ignition harness, tap the accessory wires in passenger kick panel, or tap the fuse in the box
there is a c5 FAQ under car audio
