Just Received Vararam Intake - Very Upset With Quality/Fit Finish
Old 02-16-2009, 04:40 PM
DevilMan02
DevilMan02's Avatar
Default Just Received Vararam Intake - Very Upset With Quality/Fit Finish
So I just received my intake -- the vararam VBR2. The 2 is supposed to be the revised version of the intake system.
Now when I purchased it, I was already aware of the 'home-made' asthetics of the system. That doesn't bother me because I'm mostly interested in the performance gains. I haven't installed it yet, however I pieced it together in my living room just to see how the system will be installed once I go out and take things apart on my car.
Here are my gripes:
1) The instructions. They're terrible and are completely useless. Thanks for including pictures and a vague description of how to put things together. These are nothing short of what you'd expect from an ebay vendor--selling a set of instructions that have been copied hundreds of times. Thank GOD someone put together a great D.I.Y guide for the installation. If I were Vararam, I'd be pretty embarrassed that a CONSUMER has better installation instructions than provided.
2) The seals/foam on the bottom half (the ducts). They say to put the foam on after the system is installed of course...but I lined up the pieces just to see how they'd fit. They do fit (sort of) however the person that cut the holes for the screws either has a poor template or an 8th grade education. They don't line up at all--not even if you flex the system as it might once installed. If you line 2 holes up, the other 2 screws might as well be a city block away.
http://farm4.static.flickr.com/3621/...1eac7913_o.jpg
Here you can see 1 and a HALF screws make it, look closely and you'll see the bottom two don't at all.
http://farm4.static.flickr.com/3216/...c9e86be246.jpg
Another angle with better lighting.
Now -- Even forgetting about the holes, the foam covers several areas of the ducts, obstructing airflow. Looks like I'll be doing a lot of cutting and reshaping.
3) The seal/foam for the top housing doesn't wrap around the top completely. They made a half-a$$ed attempt at putting it all the way around but left a gap about a centemeter or two wide for direct air to pass through--unfiltered. Again, probably a poor template.
http://farm4.static.flickr.com/3432/...6272ce9a_o.jpg
http://farm4.static.flickr.com/3437/...2f8044a7_o.jpg
http://farm4.static.flickr.com/3182/...1188afd7_o.jpg
As you can see, the filter as a whole, is a little loose in the top and bottom. Once you lock it in place it'll tighten up. Yes, however the locks are on the left and right, not the top and bottom where the gaps are the largest.
4) The fit and finish of the top and bottom as a whole is kind of crappy. Once again, the fit and finish of the foam doesn't make it--this time it's not even the right shape for the top. The marriage of the bottom ducts to the top housing don't share a similar shape--a poor design if you want to use the foam seals. As you can see here, once you compress the foam, it bunches.
http://farm4.static.flickr.com/3482/...cf95e37a_o.jpg
http://farm4.static.flickr.com/3179/...52fcefc1_o.jpg
Additionally, pieces of the intake have been what would appear to have been sanded and other pieces have been scribbled out and written over.
http://farm4.static.flickr.com/3273/...22e23a94b2.jpg
Here's the sanded area that has significantly weakened the corner lip of where the top and bottom halfs connect.
http://farm4.static.flickr.com/3325/...06fcb155_o.jpg
Additionally, each duct is made of 2 halves that seem to be glued together or bonded in some way. Another shoddy job here since there are many areas that missed the glue and can therefore pass air between it. How is this system supposed to 'pressurize' (if that's even what it does) at 60+ mph speeds??
Last but not least there are plastic burrs all over the place. 2 or 3 minutes is all it takes to remove them by hand so they don't get sucked into the intake.
To be quite honest, I'm really pissed off that $300 dollars can't buy me an intake that has some $2 dollar foam that's cut correctly.
It really makes me wonder about all that bullsh-- testing and writeups they have. I wonder who they hired to write all that and why they couldn't have used that same person to write a decent set of instructions.
Perhaps they could pay him a few dollars more to do a little quality assurance as well. I'm very unsatisfied with this system already and it's not even on my car.
Those of you who are going to comment on the amazing power gains--just remove your intake system entirely. You might as well -- with the gap I've got in mine I might as well have a vaccume cleaner for a motor. Sucking up sand, dirt, and debris as I drive along the roads of Florida.
DevilMan02 is offline
Old 02-16-2009, 04:48 PM
Dominic Toretto
Dominic Toretto's Avatar
Sorry to hear how dissapointed you are about the product. I have heard the build quality is humorous but the results are otherwise solid. can you post a close up picture of the actual intake opening where the foglight housing part connects to it?
-Alex
Dominic Toretto is offline
Old 02-16-2009, 04:58 PM
hawk4077
hawk4077's Avatar
Thanks for the heads up guess i'll wait for the VBR3 model to come out. Got there power duct more for looks than anything but it dose not work with stock unit. but there ad sounded good.
hawk4077 is offline
Old 02-16-2009, 05:07 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sorry about your intake, From what I have read here on the forum, I won't be buying one, It is a shame that they have no quality control, I have read 3 maybe 4 threads about the same issue this week alone. If it were me for 300 bucks I would be sending it back.
JMO.
Bill K
Mr.Bill is offline
ecoman
ecoman's Avatar
Sad for the price you paid you would expect a little better quality.My car had a bpp votex ram air on it when i purchased it no problems with it so far. good luck with the install.
ecoman is offline
Old 02-16-2009, 05:22 PM
Ryan040675
Ryan040675's Avatar
This thread, along with the 300 dollar price tag is exactly why I won't be buying one. I think these should retail at about $49 based on what I just saw.
Ryan040675 is offline
Old 02-16-2009, 05:28 PM
11psiGSR
11psiGSR's Avatar
Wow. I have certainly heard of the quality issues many times on this forum, but this puts it into perspective. A car as great as the C5 deserves something better.
Your post justified the extra $200ish for the Calloway Honker for me.
11psiGSR is offline
Old 02-16-2009, 05:39 PM
HiVoltge
HiVoltge's Avatar
St. Jude Donor '08
Thanks for the heads up...
its amazing how much vendors/manufacturers charge for us vette owners for poor quality crap...
HiVoltge is offline
Old 02-16-2009, 05:41 PM
Rag-Top Rick
Rag-Top Rick's Avatar
Even though many people report gains from this system, it has MANY flaws!
Common sense tells you that the filter is very under sized for serious horse power applications!
The foam seals clearly don`t work properly, thus the system really isn`t pressurized, as it has leaks all around the lid!
If you doubt me, try an automotive smoke machine designed to detect intake leaks, I did and I`m am confident your results will confirm my statement.
When I reinstalled my old twin flow on my blower car the twin filters flowed so much more air I had to have the idle re-tuned.
Just my opinion based on real world trial and error...
Rag-Top Rick is offline
Old 02-16-2009, 05:43 PM
Alaskanpilot
Alaskanpilot's Avatar
St. Jude Donor '08-'09-'10
Wow... sounds like you got a really lousy setup. Mine was nowhere NEAR that bad; everything fit, it all lined up; the screws lined up... the foam fit, the filter sealed beautifully. After installation, I didn't have to re-adjust anything... was lined up perfect right off. I wonder if VR just sent out a bad batch this month or something, prompting all these sudden complaints at once?
I DO agree with the instructions... I took one look and threw them straight away into the trash with a laugh. Who are they kidding?
I used CajunDude's instructions, modified a bit for me having a Z06 vs. a coupe. Easy. Tedious, but easy. I'd do this again.
If you do return it, hopefully you didn't buy it from that certain vendor who charges a 25% restocking fee... Ouch! Steep "fee" for not accepting a faulty product.
Alaskanpilot is offline
Old 02-16-2009, 05:55 PM
jdmvette
Night Owl for life
Support Corvetteforum!
jdmvette's Avatar
Received 3,247 Likes on 1,668 Posts
that's pretty much what i've always read about vararam.
callaway honker does the same thing as the VR, but the quality is top notch.
jdmvette is offline
Old 02-16-2009, 06:24 PM
Chicago1
Chicago1's Avatar
Dang another thread this week. what vendor did you get it from?
Chicago1 is offline
Old 02-16-2009, 06:31 PM
jrprich
jrprich's Avatar
I had the same experience when I bought one a year or so ago......put it back in the box and returned it. Bought a vortex Rammer and I am happy with it.
jrprich is offline
Old 02-16-2009, 06:34 PM
jobear
jobear's Avatar
We should not allow venders like that on this forum.
jobear is offline
Old 02-16-2009, 06:39 PM
EPMM 03 C5
EPMM 03 C5's Avatar
Well i guess my mind is changed in buying this product!
EPMM 03 C5 is offline
Old 02-16-2009, 06:45 PM
Bret01Z06
Bret01Z06's Avatar
I have had mine for 2years now with no problems. I don't remember mine fitting that bad.
Bret01Z06 is offline
Old 02-16-2009, 06:49 PM
Plasticman
Plasticman's Avatar
The fact that the "Made In /////" was deleted, says they have changed "factory" locations. probably now made in Timbuktu or Bangladesh.
Plasticman
Plasticman is offline
To Just Received Vararam Intake - Very Upset With Quality/Fit Finish
Old 02-16-2009, 07:35 PM
DevilMan02
DevilMan02's Avatar
-Alex
As requested:
http://farm4.static.flickr.com/3214/...c06a26ca_o.jpg
http://farm4.static.flickr.com/3351/...ddcb9e20_o.jpg
http://farm4.static.flickr.com/3428/...4f33a636de.jpg
http://farm4.static.flickr.com/3476/...6cfe29d1_o.jpg
http://farm4.static.flickr.com/3182/...f40d38bb_o.jpg
Also while I was taking these photos, I found this:
http://farm4.static.flickr.com/3641/...8e8c74d8_o.jpg
http://farm4.static.flickr.com/3468/...f61582ac_o.jpg
You be the judge: Precision performance piece or sloppy piece of sh**?
Old 02-16-2009, 07:38 PM
DevilMan02
DevilMan02's Avatar
Plasticman
Awesome. Good to know it's in 'Euro'. Why not just say Mfg on Planet Earth? Who the hell puts that?
Old 02-16-2009, 07:44 PM
Mr.Bill
Mr.Bill's Avatar
I still say send it back, That is uncalled for.....
Talk about Corvette Tax. I don't care if it gives you 100HP, My car deserves better.....
Mr.Bill is offline
Quick Reply: Just Received Vararam Intake - Very Upset With Quality/Fit Finish
