how to remove side marker light?
04-15-2009, 01:47 PM
How do I remove my rear side marker lights?
04-15-2009, 01:50 PM
Cruise-In X Veteran
Remove the brake lights and dig in.
04-15-2009, 01:58 PM
yep...I am putting in the diamond cut clears on rear sides of mine...and asked this ?....Just take out end tailights and reach thru...was advised to use a magnetic screwdriver and have an L shaped one on hand as its not the easiest angle to get too.
04-15-2009, 02:01 PM
Location: Dear Karma, I have a list of people you missed.
Quote:
Originally Posted by
JJS04
And an
easy does it on re-tightening the two nuts on each light.
04-15-2009, 09:13 PM
'20-'21-'22-'23-'24
LoneStarFRC
And an easy does it on re-tightening the two nuts on each light.
The nuts are self tapping and you don't have a lot of room to work in there. A box end wrench is a good tool to use for the job.
04-15-2009, 11:02 PM
JDs00PewterCoupe
And hope you have arms like pipe cleaners, casue if you have decent size arm your gonna get torn up. I look like it fought a thorn patch
04-15-2009, 11:14 PM
St. Jude Donor '08
ctvette2003
my friends tell me they've seen bigger arms on glasses. looks like the jokes on them because it made this job easy
04-16-2009, 12:23 AM
well i was hoping for a easier way but O" well here I go!!
thanks everyone!
04-16-2009, 12:50 AM
St. Jude Donor '09
time4prime2shine
Best way is through the outer tail lights. Really easy, should only take a few mins.
04-16-2009, 07:21 AM
More work, but you can remove the rear wheel and black plastic wheel well cover and you have plenty of room.
04-16-2009, 03:27 PM
Thanks everyone for the info...took about ten minutes!
1998 ,
1999 ,
c5 ,
corvette ,
coveete ,
delete ,
light ,
lights ,
marker ,
rear ,
remove ,
side
