What % of oil life remaining do you change your oil?
What % of oil life remaining do you change your oil? I've had my garage queen for right at a year and have not changed the oil yet. They changed it the day I picked it up and I have about 3500-4000 miles on it right now. The DIC says I'm sitting at 51% oil life remaining. I was just curious when you guys get to changin'?
Received 8,919 Likes
The factory recommendation is to change the oil when the DIC indicates to change it, change at 10K miles for early C5s or 15K miles for later C5s or once per year. If you drive in dusty conditions then you have to shorten the interval as the OLM isn't able to factor in the dust problem. I change mine once per year which means around 4000 miles. Since I track the car and the oil temps get pretty high for extended periods of time the OLM usually indicates around 40% when I change it.
Bill
Bill
This is the only time in your life it is OK to listen to your DIC
change it anywhere from 15% down to 1%...
So, I do. Once a year or when I'm down to 1% - that's when I change mine.
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I think the last time I changed mine was at 10%. No particular reason other than my other two vehicles were having their oil changed, so I had the Vette changed too.
Received 1,673 Likes
I change it at 1 year or 10,000 miles whichever is first!
Wow! I changed mine @ 45% because in my 2007 Cadillac CTS if it got down to 37% in the DIC I had like a quart of oil left. I would love to trust my DIC but does anyone have a rule of thumb mileage wise for synthetic oil in a c5?
I normally hit the one year point now before 0% although I used to run down to about 5% when it was a DD
This year I had 29% remaining but I'd be happy to run down to 0% if I covered enough miles. Synthetic oil is good stuff as the oil analysis posted here shows.
Received 19,234 Likes
'20-'21-'22-'23-'24
GM recommends you change it at least once a year - or when the DIC tells you to. When I had mine, I usually got around 4500 miles/45% oil life remaining when the year time period hit.
