post pics of a4 aftermarket shifter handles
hey guys.. i'm sick of looking at my shifter in my c5... i have a a4 after test driving a trans am the other day i really want a different shifter.
the t/a that i drove had a ball type shifter, you push it down and pull back into the gear. very nice piece..
any vendors sell something on here?
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Bill
I bought an adapter from MidAmerica a few years back. Then picked up a cue ball that I liked and drilled and tapped it. It's been working great ever since. Just push down and pull into gear.
yyukon, is that a C6/A6 shifter ****, complete with the push button installed on a C5/A4? If so, that is what I want and need.
Was this a kit or was it hard to do? I love the button being in the front of the ****, it is like a gun.
Padrino
[/IMG]
If you have good mechanical skills and some patience it is not to bad of a job. You have to remove the center console and shifter assembly from the car.Be very careful when removing the shifter to transmission cable. I broke my shift cable and it is a real pain to replace.
It is a c6/a6 on a c5/a4. Best thing to do is buy a complete c6/a6 shifter assembly (Boot, Shifter ****, Etc.)
and switch out the shifter shaft and **** assembly. c5/a4 pictured on top and c6/a6 pictured on bottom.
I did it the hard way and bought a parts only c6/a6 shifter. Then ordered a new shifter ****. I was missing some parts and had to improvise. See the link below and it will give you an idea of what is involved.
Any questions, just ask.
http://forums.corvetteforum.com/memb...r-upgrade.html
referenced directions to accomplish this swap
Did a bit more research on the "how to" of this. check out the following 2 webpages for more info....
http://www.theredlion.us/C6%20A6%20S...20by%20WHT.pdf
Padrino
Padrino
