Code P-0410
Code P-0410
My 2000 Vert is coding P-0410. Secondary air system trouble.
Checked my air pump and it is running for 60-90 seconds on cold startup as required. Checked hoses for leaks. Checked and cleaned driver side check valve OK. Blew air through passenger side check valve(PITA to get to) with exhaust manifold connection removed, all OK. Line to air cleaner OK.
Could blower motor be weak? After resetting code, it came back in after 5 minutes of driving.
Any ideas? Thanks
Any ideas? Thanks
Any ideas? Thanks
Any ideas? Thanks
I'm not sure that answers the question, but I appreciate the response. This is a 13k mile car, I would hope the fact that it all at least "appears" as new, that I would not be having these issues. What is the suggested method of testing the cap and back to the original question, should the vacuum or pumped air pulse?
My blower did not pulse, it is a constant large volume of air flow. There is a vacuum controlled valve by the blower motor that needs to be open to get sufficient flow to not drop a code. Even if the valve does not open fully, you will get some flow but not enough to keep from dropping code. My trouble was leaky acid battery, very small vacuum hose in wire bundle below battery. Acid ate a hole in mine. If it is a vacuum problem, your AC/Heater venting selection will not change. Cannot adjust from defrost to heater to vent. Hope this is some help. I did a write up on my repair, I know it is in the forum somewhere. No more acid batteries for me.
I have the AC problem as well. Must be a vacuum issue. I hate hate hate the thought of unwrapping that bundle (not that I actually know which one it is). Re-wraps are never the same.
