1997-2004 C5 Sequential Taillights Kit! New product from RPI Designs!
Platinum Supporting Vendor
The 97-04 C5 Corvette sequential harnesses will convert the taillights on your 1997-2004 Corvette into Sequential Turn Signals. The 97-04 C5 Corvette sequentail taillight kit contains two pre-wired harnesses that simply plug into your existing sockets. Return to stock operation at any time by unplugging the harnesses. It doesn't get any easier that this!
These harnesses feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, our modules sense your car's flasher speed and adjust the sequence timing for you. Want more separation between individual lamps? Just put in a slower flasher!
You will not find a nicer C5 Corvette sequentail taillight kit!
Available here: http://rpidesigns.com/shop/item.asp?itemid=1658
__________________
RPI DESIGNS, LLC. - C5/C6/C7 Corvette Parts
4000+ C5/C6/C7 Parts & accessories - Forum members get 10% off with SS2007 coupon at checkout
Like us on www.facebook.com/rpidesigns and you might win $100.
Our brand new C7 Corvette Z06 Style Side Skirts come painted in Carbon Flash Metallic, see them here!
email: rpi.designs.customerservice@gmail.com Web: www.rpidesigns.com
I would presume that you would have to buy a bypass flasher unit and swap out flasher units to get the desired results.
Received 19,233 Likes
'20-'21-'22-'23-'24
Sounds like a very nice product - best of luck with it.
Please remember that coupon code SS2007 will save you 10% at checkout.
Received 2,673 Likes
2018 C5 of Year Finalist
Do these work with LED Tails?
