98 Drivers side power window motor bad
8th Gear
I'm getting power to the motor but no action. Can the motor assembly be removed without taking out the window regulator?
Thanks,
Ed
Thanks,
Ed
Premium Supporting Vendor
I would be happy to help you out with new, but GM only sells with the regulator. The reason is, normally if the motor goes, not too long after that so does the regulator.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
8th Gear
I had some luck. Tapped the motor with a small hobby hammer (love tap) and it started working. Now I want to put the door panel on and I need the big grayish black rubber/vinll cover that I removed to look inside the door replaced. Mine fell apart. Anyone know what to call it and where to get one?
Ed
Ed
