need tire fitment help for up front.. asap
i have to buy 2 tires for the front of my car cause my alignment is all messed up.. the rim and tires currenty on the car are 19x10 and 19x11 with 275 30 up front and 305 30 out back...
i have a chance to get a almost new 305 30 half off so if i bought another one will they fit up front with any problems???
St. Jude Donor '08-'09
You can't run same size tires front and rear, it will throw your TC/AH into a tizzy. Unless you want to run constantly with the TC/AH off, which is not advisable.
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I would not run the same size tire front and rear (likely to cause occasional traction control engagement during normal driving), and I would not put a 305/30 on a 10" wide wheel either.
Stick with the 275s.
