Upgrading your C5 rear with C6 Z06 guts
Old 08-31-2010, 09:55 PM
  #41
mickey_7106
mickey_7106's Avatar
Subscribed
Old 09-01-2010, 08:26 PM
  #42
mickey_7106
Would you recommend this swap on a 3.15 case? i dont know what a 1 or 3 "rib" case means
Old 09-01-2010, 09:12 PM
  #43
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres a THREE RIB unit:
Non three rib
Old 09-03-2010, 02:54 PM
  #44
mickey_7106
mine looks like the one on the first pic. i thought the 3 rib was for '01 and up?
anyways from this quote i can use a brace if i have a 1 rib diff
Originally Posted by DTE Powertrain
Both the 2-series and 3-series cases come from the manufacturer with either the 1 or 3-rib mounting flange reinforments. Both types will and have been broken under high power/low gear ratio applications.
We have also seen where the Z06 case has come with either a 1 or 3-rib mounting flange reinforment at random also, so there certainly is nothing special about that case itself. In the early model cases, it was completely random as to what type of case one received from the manufacturer, no matter what gear ratio was O.E. installed, but as of 2003 and up, ALL 2 and 3-series cases come standard with 3-rib mounting flange reinformant from the manufacturer no matter what gear ratio is installed from the manufacturer. For 95% of the market, either version suits their needs just fine without any negative issues what-so-ever, but for the hardcore drag racers, it's recommended to opt for the later version, as they need all the help/strength thay can get at the track.
However, there is no strength difference between the two types when our differential strut is is utilized for added driveline rigidity because the strut bracing assembly/bracketry removes the severe structural loading from the differential/transmission case at that crack-prone mounting flange area anyway and spreads the shock loading across/evenly to the strongest areas of the entire driveline, preventing driveline fracture. These differences are one of the reasons why we developed the M6/M12 and A4 differential strut kits in the first place. Necessity is often the driver of invention...
Best Regards,
DTE
Old 09-03-2010, 02:57 PM
  #45
c5BlackBeauty
Corvette C5 Enthusiast
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by tlc0706
Thanks for the info.....catalogged....don't remember seeing this before...
Didn't even know that would be possible.
Old 09-04-2010, 12:04 PM
  #46
ragtopws6
ragtopws6's Avatar
The 3.15 and 3.42 case are the same but the 2.73 is different.
The 3 rib is stronger by design but when you have wheel hop, I have seen broken cases both on the 1 rib and 3 rib cases.
I personally would start with a 3 rib case for any performance builds.
Old 09-04-2010, 02:23 PM
  #47
mickey_7106
i see thanks for the info/help. ive never had wheel hop so i hope that wont be a problem in the future *crossing fingers*.
would i be better off if i get the parts micro polished?
Old 09-05-2010, 10:26 AM
  #48
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Rick, good meeting you at the americanracingheaders.com compound last week
I swapped the C6Z short and long shafts into a diff 2 weeks ago
pretty basic, just need a press for the short side
I have done a bunch of 300M's in the past
great info here!!!
Old 09-06-2010, 11:42 AM
  #49
ragtopws6
ragtopws6's Avatar
great info here!!!
It was nice meeting you too Steve. I hope we can get together at a Vette gathering so we can talk cars.
Old 09-06-2010, 11:47 AM
  #50
ragtopws6
ragtopws6's Avatar
Micro polishing the parts does help if you are looking for the last ounce of performance but the cost doesn't off-set gain IMHO. Only part I have micro polished are the gear sets.
Old 02-07-2011, 08:36 PM
  #51
ILM-Express
MFIC
ILM-Express's Avatar
So if my 99 has the 3.15 can I use a higher ratio C6Z upgrade ? what is the gear ratio on those ?
3.42 ?
Old 02-07-2011, 09:16 PM
  #52
ragtopws6
ragtopws6's Avatar
3.42 ?
You can upgrade all the parts EXCEPT for the ring and pinion gears. They are much bigger in size. And yes, it's 3.42's.
Old 02-07-2011, 09:24 PM
  #53
momo20
momo20's Avatar
wow! thanks for the side by side shots...and thanks for takin the time to do all of that..good stuff!
Old 03-27-2011, 08:53 PM
  #54
YO-EL
YO-EL's Avatar
Has anyone done this?
Post the results & your thoughts!!
Old 03-27-2011, 08:58 PM
  #55
YO-EL
YO-EL's Avatar
So no 3:90's?
Old 05-09-2011, 10:11 PM
  #56
speedyhawk101
speedyhawk101's Avatar
Originally Posted by YO-EL
So no 3:90's?
I believe a 3.90 gear set for the C5 diff will work for the swap mentioned in this thread.
The C6Z Gear Sets will not work sice they are pysically larger, if I'm reading this thread right.
Old 05-10-2011, 09:23 AM
  #57
ragtopws6
ragtopws6's Avatar
Correct!
To Upgrading your C5 rear with C6 Z06 guts
Old 07-03-2011, 02:40 AM
  #58
Gradient
Gradient's Avatar
Default Help.
I think this is an upgrade I may need. I have an 03Z and the diff seems to have way too much play. The left side cover is leaking pretty bad as well (not the axle seal).
When I lift the car, put it in gear and then turn one of the rear wheels, there seems to be way too much play. It goes "clank clank" as I wobble the wheel left and right (the wheel turns about 2-3 inches in each direction). Is this normal? Or will I be replacing the diff soon?
If I do need to replace the diff, I would like to upgrade as mentioned in this thread, but I don't have the tools necessary. Any recommendations for a shop in San Diego CA that could do this for me?
Thanks in advance.
Old 10-19-2011, 10:34 AM
  #59
que4dog
que4dog's Avatar
Originally Posted by Bill Curlee
Before you spend a lot of cash and wont be able to use the parts that you get,,,,,I believe that you will have to properly set up the pinion and differential side bearings if you replace those parts!!!!!
. Thats what prevented me form up-grading that portion of the rear-end. It takes special alignment tools and knowledge to do the pinion. Its not a simple procedure if you don't know what your doing. Google that Kent Moore alignment tool that listed in the post and you will see whats involved.
" Here is the calculation on C5 pinion shim setup:
B1 = pinion & drivers side measurement (need Kent Moore tool J42168)
B = 0.197"
B - B1 = B2
A1 = numbers on pinion gear
A = nominal value of 4.055"
A1 - A = B3
B2 + B3 = pinion shim thickness "
Bill
Bill, do you have any new info regarding setting the pinion carrier? My stock carrier needs replacement & I want to upgrade.
Old 10-19-2011, 10:57 AM
  #60
had2have-it
had2have-it's Avatar
So on this type build, if you want 3:73 or 3:90, it can be done when using aftermarket ring/pinion? If so I would need ring and pinion for a C5 or C6? (The car is a '01 with factory 3:42)
Quick Reply: Upgrading your C5 rear with C6 Z06 guts
