Cig lighter does not work, but one in console does...
Old 12-21-2009, 08:50 PM
crAzy
crAzy's Avatar
Default Cig lighter does not work, but one in console does...
I checked both fuses and they are both perfectly fine. I had my radar plugged into the cig one, but i unplugged it for something then plugged back in and nothing. Usually when this happens the fuse would pop but this time it didnt. I took the radar and plugged into the console one and it worked perfectly fine. I have yet to take apart the center console to check connection on the back but i doubt that could be the problem. I just recently took it apart to lay dynamat in. Was working for a good week. Any ideas besides checking the connection?
Old 12-21-2009, 08:55 PM
JeepTJ
JeepTJ's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I had the same problem. The connector on the back came off. Mine happened after installing a HUD.
Old 12-21-2009, 08:56 PM
DevilMan02
DevilMan02's Avatar
Having the same exact problem and my connection IS fine. Just installed a short throw and made sure that the connection was on tight. Can someone post pictures of where to look for the fuse?
Old 12-21-2009, 09:01 PM
crAzy
crAzy's Avatar
Its #7 on the fuse panel on passenger side by the feet. Pull carpet back and remove foot panel then you'll have access to the fuse box. If you look on the cover that you removed you should see #7 cig/lghtr or something like that.
Old 12-21-2009, 09:11 PM
Silverbullet00
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
My cig/ltr has never worked. Guess I will check out why. Santa might bring me a ticket source detector!
Old 12-21-2009, 09:23 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Like stated above you will need to pull the bezel and check the connection there had mine come loose but it's an easy fix
Thanks,Matt
Old 12-21-2009, 11:29 PM
flynbyu2
flynbyu2's Avatar
St. Jude Donor '10
Get yourself a volt/ohm meter and make sure you have power to the connector. No power would most likely be blown fuse. Power to the connector means bad cig lighter unit. They do in fact go bad from time to time.
Old 12-22-2009, 12:24 PM
Received 19,186 Likes on 13,910 Posts
'20-'21-'22-'23-'24
Could be that the unit that the wires plug into is bad. If you have power up to the wire connector but not to the cig lighter itself, then there you have the solution.
Old 12-22-2009, 05:57 PM
Chicago1
Chicago1's Avatar
I had the same issues and the wire came out in the back it pops out from time time. I may just leave it off next time I never use it anyways.
Old 12-22-2009, 06:29 PM
SCM_Crash
SCM_Crash's Avatar
Had this issue too. It was the fuse. Separate fuse. On a side note, I don't smoke so I never tried the cigarette lighter. Looking at the lighter itself it looks like it has never been used. Anyway, some guy asked me for a light and we tried to use the lighter in the car and it would pop and get kind of hot, but not actually enough to light the cigarette. LOL I told the guy "It's a sign to quit."
Old 12-22-2009, 07:19 PM
crAzy
crAzy's Avatar
Well took it apart and ended up being a loose connection. Kinda wierd though. But its fixed.
Old 12-28-2009, 06:39 PM
Joe Babe
Joe Babe's Avatar
sounds like a separate fuse
Old 12-28-2009, 07:53 PM
Jeff in Den
Jeff in Den's Avatar
Mine was intermittent....I reached back behind it, found the wire and just gave it a little twist, and has been working fine.
Old 12-28-2009, 08:49 PM
Daddyrama31
Daddyrama31's Avatar
Just replace my #7 fuse. Now she works great.
To Cig lighter does not work, but one in console does...
Quick Reply: Cig lighter does not work, but one in console does...
