Horn blowing for no reason
Old 01-18-2010, 10:48 PM
wlaver
wlaver's Avatar
Default Horn blowing for no reason
The other day my horn on my 2000 vette just started blowing for no reason. I disconnected the battery, only to find my battery dead 2 days later. After recharging and connecting battrey back the horn was blowing again, went inside and hit the horn button on the steering wheel and it stoped. Looks like it is the horn contacts in the steering wheel. How does the horn button cover come off and what do you think about this repair?
Old 01-18-2010, 11:12 PM
8VETTE7
8VETTE7's Avatar
Received 1,818 Likes on 1,613 Posts
It's blowing for a good reason actually. The horn membrane switch is going bad. Not an overly common problem but comes up once a month or so. Here's a DIY repair thread that is not for the faint of heart.
http://forums.corvetteforum.com/c5-t...brane-fix.html
Go to page 2 and post #39 for availability of a replacement membrane switch. Also available from Ecklers as of just recently.
Here's another thread from the past week or so about the same issue:
http://forums.corvetteforum.com/c5-t...-this-out.html
Old 01-19-2010, 12:05 AM
wlaver
wlaver's Avatar
thanks.Is there 2 screws to remove in order to get the steering wheel off?
Old 01-19-2010, 12:32 AM
8VETTE7
8VETTE7's Avatar
As I understand it there are 2 torx head screws (T30) that must come out of the back of the steering wheel center section to remove the airbag component (SIR). The steering wheel itself does not have to come off. Be sure to disconnect the battery at least 10 minutes before you begin removing the air bag so that it does not go off in your face.............
I have read that you need the Torx Head bit that goes in the end of a socket and then need a short extension on the end of a ratchet to be able to get the screws out. Very tight place to work. You need a T30 with some length on an extender bit to get up in there.
The trick is to tilt the wheel up and turn the wheel so that the screw portion is facing down so you clear the dash.
Once the air bag section is off it shoulf be exactly as described in the first link I gave above.
HTH
Old 01-19-2010, 12:40 AM
wlaver
wlaver's Avatar
Thanks Chuck. I sure hope if I disconnect the battery for 30 minutes that It will be safe to work on.
Old 01-19-2010, 02:39 AM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Disconnect battery and pull fuses labeled for SDM in passenger footwell.
Ecklers sells them now
http://www.ecklers.com/product.asp?p...dept%5Fid=1717
A whole lot better than buying an airbag.
http://forums.corvetteforum.com/c5-t...ane-fix-3.html
Old 01-19-2010, 07:36 AM
DevilMan02
DevilMan02's Avatar
I agree with everything except I pulled the fuse under the hood. Much easier.
To Horn blowing for no reason
Quick Reply: Horn blowing for no reason
