So I get this kit, charged 79.99. I read the instructions, tells me to remove all 8 T-15 screws for the tail lights. I guess I should have just used common sense as I didn't see what I could do after I had the screws removed. You just slap em on after you clean the lenses. anyway I hope that is all you do LOL!
Easy installation with no modifications,drilling,velcro,or hardware required.The tail lamp blackouts install with your existing tail lamp housing screws.Front parking lamp blackouts fit between parking lamp and fascia for a secure fit,simply slide in to install.Reverse and 3rd brake lamp blackouts are installed with CLEAR high performance 3M tape.
Reason: added install description
