the best c5 production year to buy
Old 02-02-2010, 02:12 PM
cnd_beancounter
cnd_beancounter's Avatar
Its probably more important to find out the exact build date of your car. I would stay away from fridays more than a specific year.
Old 02-02-2010, 03:01 PM
Amherst
Amherst's Avatar
I too have heard that '99s are the way to go!
  • Only real men drive 99s
  • You can party like you're driving a nine-teen ninety-nine
  • 99 was the great one's number
  • 99 luftballoons
  • 99 is the largest 2 digit number there is
Old 02-02-2010, 03:24 PM
VR-4ever
VR-4ever's Avatar
2001 Changes
  • return to 28# injectors for all models.
  • Second Generation Active Handling
  • Nassau Blue discontinued
  • Alternator 'clutch' pulley added on A4 cars
  • New soundproofing + foam in all cars
  • Smaller keyfob
  • electrochromic dimming rearview and driver's mirrors
  • lighter AGM battery
  • Thickness + Material in vert change
  • Chrome exhaust tips for coupe + vert
  • 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
  • LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
  • All Corvettes now have the LS6 intake manifold
  • All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
  • LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
  • Hardtop/FRC discontinued - Evolved into Z06 model
  • Pup cats added to all models
  • Stronger synchros in all transmissions
  • Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
    metal valvestem caps (late year)
  • Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
  • Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Old 02-02-2010, 03:30 PM
RSchleder
RSchleder's Avatar
Buy the lastest model year you can afford
Old 02-02-2010, 04:31 PM
tommie
tommie's Avatar
02!!!
because that's what i have
Old 02-02-2010, 04:37 PM
joshtownsend
joshtownsend's Avatar
If Tommie has a 2002.. then that's the way to go..follow him!!!! I did..hahaha
Old 02-02-2010, 04:40 PM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
  • 99 luftballoons
Def. true
Old 02-02-2010, 04:55 PM
Dominic Toretto
Dominic Toretto's Avatar
2001s get you laid by Jessica Alba/Thread.
-Alex
Old 02-02-2010, 05:20 PM
Amherst
Amherst's Avatar
No sir, that was definitely the 1999s. 2001s were Susan Boyle!
-Alex
Old 02-02-2010, 05:41 PM
Blue 92
Support Corvetteforum!
Blue 92's Avatar
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Originally Posted by jrose7004
Why the 04 of course. It was the last year they made C5's so all of the bugs were worked out.
Except for the C6 gas tank changes.
2001 and up was my choice. Largest # of changes took place in 2001, not much for non Z06 cars after than except the Mag Ride suspension, the 03 Anniversary package and the 04 Collectors.
Old 02-02-2010, 05:43 PM
Blue 92
Blue 92's Avatar
Originally Posted by 8VETTE7
If I were in the market for a C5 today and knew what I know about the fuel tank issues on the 03 and newer i would get a pre 03.
http://forums.corvetteforum.com/c5-t...uel-leaks.html
Late 03.
Old 02-02-2010, 05:45 PM
rdline
rdline's Avatar
Originally Posted by STALION
Find one with low miles dated 2001 and up! I say this because the majority of changes occurred in 2001 and not to much was done after.
Start at 01 and work toward 04 with best condition and lowest miles in the forefront of those years. If you like mods and find one that way the market is good to buy those , maybe 20 cents on the dollar for the mods
Old 02-02-2010, 06:05 PM
  #33
ALLEGRO
ALLEGRO's Avatar
Consumer Reports actually leans toward the 03 for some reason. The 04 is a close second, and the earliest years were the most problematic.
I agree with and earlie thread, find one that has been well maintained.
Old 02-02-2010, 06:11 PM
  #34
SCM_Crash
SCM_Crash's Avatar
I wouldn't say that. The retarded Column Lock problem went on to plague the C6s too. LOL
Aside from that, I'd say that it's a tie between 02 and 04. The difference being that the 02's fuel system is easier to mod while the 04s are simply newer.
Old 02-03-2010, 09:24 PM
  #35
rebelheart
rebelheart's Avatar
02's dont leak fuel and go up in flames also.
Old 02-03-2010, 09:33 PM
  #36
craig04c5
craig04c5's Avatar
I have to agree. I have a 2004 and had to have the crossover pipe replaced in addition I have had a lot of other issues like leaky rear axle seals (3) Water pump, oil pan gasket for 2 piece oil pan, delimitation of both door panels (twice), clutch slave etc. All with under 30K miles. Fortunately all except the water pump and the now leaking rear seal were replaced under new or extended warranty. My friend has a 97 and the biggest issue he has is the passenger side window motor not working, which I understand is due to a lack of use so it could be prevented very easily by just using the power window.
Old 02-03-2010, 10:18 PM
  #37
yelloyello
yelloyello's Avatar
CI 6-7, 9-10 Veteran
Couldn't have said it better myself.
To the best c5 production year to buy
Old 02-03-2010, 10:25 PM
  #38
jlbruggeman
jlbruggeman's Avatar
Newest, cleanest example that you can afford.
Old 02-03-2010, 11:05 PM
  #39
Wicked C5
Wicked C5's Avatar
St. Jude Donor '04
Early 03 would be the best model. The fuel system in the later models had issues with leaks between the connector pipe of the fuel tanks but my 04 will have a 98 system so that shouldn't be an issue.
Old 02-03-2010, 11:10 PM
  #40
saxtech
saxtech's Avatar
Location: Huntington Beach / Fountain Valley California
Originally Posted by JW@JWMotoring.com
Word on the street is the 99's are the best.
I got my 99 A4 Coupe with 24k miles on it about 2 months ago and heard this also - BUT no one has been able to tell me why ?
So do you know why the 99 is the best ? I'm excited to hear !
Quick Reply: the best c5 production year to buy
