Passenger Air Leak at Top of Window!
Ok, I have read the leak thread up and down. I searched just about everything. I have adjusted my window at both spots. Still the same result happens when i drive above 75mph, Loud wind noise (air leak). From what my passenger is saying is that the air leak is coming from the top of the window towards the back of the window. The weatherstripping is in good condition. So I do not see why this could be a problem. Now from what i have also read is that i may have to remove the door panel and adjust the window from there. There is a possibility the window could have adjusted itself out of position moving either forward or backwards.
It is very annoying to have an air leak. I always have to turn the radio up, but i know my passenger can hear it from their right ear. Specially when it gets windy outside and im on the freeway. Its bad. Has anyone fixed this annoying air leak after adjusting the two bolts at the bottom of the door? Im upset and annoyed that adjusting those two bolts is not solving my problem. Any ideas would be helpful. Also is there a write up on where to adjust if i do take the panel off?
Don't go over 74 mph. That will take care of that problem.
Sorry I couldn't resist that. Is this on a coupe or roadster? If it is a coupe, have you checked to see if the top needs a little adjustment to get it to fit tighter. I guess it would be the same for the roadster.
How does the seal look? Is it distorted? You can treat it with dielectric grease if its just dry. That may help. Is the blowout clip still in place?
Yes the clip in there. That is the lip looking thing sticking about 1/4 inch out from the top of the window right and that acts as a stopper for the window in a way? The seal looks good. I may try that dielectric grease. That is the stuff they try to sell you for the spark plugs right?
Have you checked the blow-out clip to make sure it is seated properly and is holding the window in place? Also, you would have to do a search but you can also move the blow-out clip one screw over; that has apparently been proven to help.
I wont be able to move the clip back. I also had the water leak and removed everything off the roof and applied tons of rtv. So i think that thing may be stuck now lol... But it still had a window air leak before i fixed my water leak.
Check out this post if you haven't seen it already.
http://forums.corvetteforum.com/1564461037-post18.html
Yea cross winds for me are terrible. Ill have to check that out when i get home. This silicone grease is the same as the dielectric grease right? Ill update this thread the next time i take the car. Its crappy rainy weather here in houston right now. But thanks for all the advice here.
