Help Please - Do you Run Invo's in 305/30/19??
St. Jude Donor '12
I need some help from you guys.
Do you run a Nitto Invo in a 305/30/19? If so, what size wheel are you running and who is the manufacturer?
If you have a Z06, did you have to remove the brake ducts?
Thanks in advance. I know a number of people run this tire in this size and the fitment is good.
chris
chris
not a top-performer by any stretch
...from Car & Driver's comparison of low-cost Summer tires:
The Nitto Invos came in eighth place out of nine tires. I'd stay away from this tire.
If we rated tires on tread design, the Nitto Invos would score high. The slashes that crisscross intriguingly through the tread had us envisioning a vicious Star Wars light-saber showdown taking place right there on the edge of the tire.
Unfortunately, the Nittos’ performance was less inspiring. They were second from the bottom in both dry lap time and braking, with both drivers reporting a soft feeling at the limit and that they were difficult to drive precisely because the grip would taper off in a nonlinear fashion. This led to more oversteer than most of the other tires exhibited, and even though they had an average skidpad run (0.91 g), the Invos left both drivers wishing for more grip.
Things were better in the wet, where Geswein ranked the Invos tops for precise responses, tied with the Dunlops and the benchmark Michelins. The tires’ predictability inspired confidence, although their lap time was still exactly in the middle.
Fairly quiet on the street loop, the Invos were below average in the dry and average in the wet, which put them in eighth place. Nitto does offer a higher-performance tire, the NT05, which conceivably could have fared better but is not available in the size specified for our test.
St. Jude Donor '12
Thanks for the info. I've had these tires for a while, I'm just dealing with a specific issue with the wheel maker. Not looking for references or comparisons on the tires - just want to make sure that others run the same size tire/wheel.
In doing my research prior to purchase I found that many others ran this setup. Please let me know if you do have this, or had this in the past.
chris
chris
St. Jude Donor '12
Thanks for the replies everyone. I knew there were people out there running them with no problems.
I assume the fitment with the outer fender is pretty flush as well. Does it stick out any?
chris
chris
