Corvette Newbie; NEED HELP WITH CODES PULLED FROM DIC on Pre-2001
Year: 2000
C1221- LF Wheel Speed Sensor Input Signal is 0
C1225- RF Excessive Wheel Speed Variation
C1232-LF Wheel Speed Circuit Open or Shorted
Active Handling/ABS warning lights started out coming on periodically but now are on all the time
Any help or direction would be greatly appreciated.
Thanks!
Thanks!
You may want to post this in the C5 Tech section. There are some down right Wizzards hanging around in tech. If you post in tech, you will get an answer as I can't ever recall the tech folks being stumped on any question. Good Luck.
