tire?
Old 03-10-2010, 07:07 PM
Clint43
Clint43's Avatar
Default tire?
can you run stock C5 tires on C5 Z06 wheels the tires i have on my car now are 17x8.5 fronts and 18x9.5 for the rears now the tire sizes are 245/45 front and 275/45 rear. can i run these tires on Z06 wheels wich are a inch wider?
Old 03-10-2010, 08:03 PM
1blkc4
1blkc4's Avatar
Default tires
not really recomended for the fronts they will be streatched.
Old 03-10-2010, 08:25 PM
mrm1149
Support Corvetteforum!
mrm1149's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
been there, done that with no problem at all with the OEM runflats. a benefit of the stiffer sidewall............
Old 03-10-2010, 08:41 PM
Toms02C5
Toms02C5's Avatar
I think you're going to have issues with the fronts -
I purchased new OEM C5 ZO6 wheels for my C5 - I did check the Goodyear specs to get their recommendations, but they had a misprint on the fronts (stating it would be OK to run the stock tires on the ZO6 wheels) - In fact, the correct specs should have told me the fronts were 1/2" too wide for the stock tires...I wore the fronts out in 3 weeks....by the way, Goodyear walked away from the issue even though I had a document showing their misprint.
I ended up going back to OEM, they were great and swapped my front wheels (that were 1" wider) for stock size (8.5) but in ZO6 style wheels at no cost -
The backs should be fine - they are within recommended specs
To tire?
Quick Reply: tire?
