How to Repair that $41 Door Reflector for 41 Cents
Hey guys. My stupid door panel reflector broke. The two little ears broke off and the reflector fell out. This has happened to me twice; The first time I just replaced the reflector. The second time I repaired it.
Here is what I did:
Daryl's C5 Door Reflector Repair
Here is what I did:
The following 3 users liked this post by DashingDaryl:
awesome should be in the diy section. Also what is the point of the reflectors? I figure by the time you open your door and someone is coming at you it will be to late and your door would get hit anyways.
JimHarris4 (09-21-2020)
Good work! There's lots of ways to skin this cat...
Happened to me yesterday. One of the ears had broken off ages ago; then yesterday number two broke off. By dumb luck I still had both ears, however. They were both hiding behind the door panel.
So all that was needed was a tube of plastic model cement and about 5 minutes of drying time. Good as new!
Received 19,234 Likes
'20-'21-'22-'23-'24
Nice write up and thanks for the info - may come in handy some day.
Here is what I did:
Here is what I did:
Thanks,Matt
tcallebaut1 (08-28-2021)
Received 1,673 Likes
Nice write up!
Here is what I did:
Here is what I did:
Good solution.
On mine I just epoxied some free metal picture frame spring clips to mine - they are just strong enough to not come loose unless you get a screwdriver and pull on them.
