Locking lug nut removal?
Well, one of my worst nightmares happened. What would I do if I ever lost the lock lug key (OEM GM part)? Luckily I discovered it was gone when I was about to bleed the brakes in my garage. After a quick search on the internet I ran down to Sears and bought a locking lug removal socket thing a ma jingy. The first two came right off. The grooved socket just bit right into the locking lugs and they turned and came. I replaced them with some old standard lugs I have. But the remaining two refused to take the bite. I just couldn't get a grip on them. I even tried hammering them on. So anyone have any suggestions?
By the way, how do you guys feel about locking lugs overall?
My car stays in my garage 99% of the time and all I have are stock Z06 wheels. Not too worried...besides, I have insurance.
As far as getting the old ones off, have you tried to 'hammer' the socket onto the lugs? It should help the socket get the necessary bite.
If not, you might try a Les Schwab tire store. They removed a set from my son's 4Runner for about $40 and it took them all of about 10 minutes.
I don't get to wound up about the locking lugs, most bad guys steel the hole car and then take the wheels and everything else off. As far as the locks that are stuck, I got a removal socket from my Snap On dealer. It will remove any lock. It is a lot better that the Sears unit. The very worst lock I removed involved applying heat to the lock,pounding on the lock tool and crank. Hope this helps.
I installed the stock lug nuts and stored the locking ones and "key" with the front plate surround If someone really wants your wheels they'll have the same tool you bought at Sears.
St. Jude Donor '08-'09
Hi There;
One of my buddies had the same problem. He had trouble with one as you are. I used a hand held propane touch. That did the trick. That nut was corroded fast.Had to use a longer breaker bar.
robsc501
robsc501
Received 19,480 Likes
'20-'21-'22-'23-'24
Some hammer a socket onto the lug and then remove them that way. If you tried that and it didn't work, take it to a good tire shop and they can usually get them off for you.
You can actullay get a replacement from the lock manufacturer...mine was Amcor (734-266-6939) and they matched the pattern by a pic i sent them....
12 point socket and a big hammer. Make sure it is a socket you dont care about or a Craftsman that you can bring back if it cracks. I have had to do this on at least three of my cars and several friends. I guess if I open up that part of my memory I have sealed up I also did it when I was working in a tire shop.
The locking lug nut key is the next to last thing you want to misplace. I'm usually extra careful about keeping track of it and putting it back. I did take all the wheels off last month for a cleaning. So I had to have it then. I'm just wondering where I put the damn thing?
Sounds like you have the GM locks which are pretty easy to remove without the key following one of the instructions in the previous posts. If you want some locks that will take it to the next level and cannot be removed by just tapping a socket or extractor... check out the Gorilla Guard Locks http://www.gorilla-auto.com/gorilla.guard.locks.
