Z51 Sway Bars - Available w/ Pfadt Poly Bushings or OEM Bushings - www.PartsTaxi.com
Former Vendor
We had run out of stock on these for a while, but now we are back up and running with both the Pfadt Poly and OEM bushings in stock and ready to go. These C6 Z51 bars and are a huge improvement over stock C5 or C6 suspension. To give you an idea of the difference;
C5 Z06
Front Bar Diameter- 30.0 mm
Rear Bar Diameter - 23.6 mm
Base C6
Front Bar Diameter - 25.5 mm
Rera Bar Diameter - 17.5 mm
This C6 Z51 Kit
Front Bar Diameter - 31.0 mm
Rear Bar Diameter - 25.6 mm
Z51 Front and Rear Sway Bar Kit - Our most popular bar kit. Kit includes front and rear stabilizer bars and bushings for Z51. We are now proud to offer our customers the choice or either OEM bushings, or polyurethane (poly) bushings from Pfadt Racing for the same price of -$192.21
We also offer the metal end link upgrade for $22.78 each. They can be ordered by using part number 20822934.
Thank You
Kevin
www.PartsTaxi.com
C5 Z06
Base C6
This C6 Z51 Kit
Thank You
Kevin
www.PartsTaxi.com
I ordered my C6 Z51 Sway Bars, Poly Bushings and Metal Endlinks from Kevin. GREAT DEAL !!!
I installed them several months ago.
Very Easy and inexpensive performance upgrade.
I even had the rear sway bar powder coated red from a local vendor before I installed it. It looks awesome from the rear now and handles great.
Bump for you Kevin.
Bump for you Kevin.
Former Vendor
Bump for you Kevin.
Bump for you Kevin.
Former Vendor
