Stock Auto Trans
Stock Auto Trans
Well i been trying to get in a vette and after have 3 mustangs all auto i was gonna try getting a c5 vette with a manual trans... there has been few i have been considering, but anyways what seems to be a really good deal came up on craigslist for a 97 corvette with a auto trans...
so my question is how is the stock automatic trans on the 97(or any c5) corvette? How do they hold up vs the manual? any info comparing the two and what you think would be great...
and for what i want outta the vette is just a dd with some bolt ons!
Received 19,309 Likes
'20-'21-'22-'23-'24
I'm on my first auto tranny C5 after having owned two other 6-speeds. While the fun factor of shifting through the gears is not there, the auto tranny is not a bad unit. I'd recommend getting the 3.15 gears if you get one. With regular maintenance, the A4 should give you a lot of trouble free miles.
At some point in time with a manual you will need a clutch and pressure plate whereas the auto trans can go almost 100,000 miles before a fluid change but I would change the fluid at 50,000,actually the auto can be slightly faster than the manual trans.
I have a C5 convertible with a 6 speed manual and it can be a hassle holding it in one place on a slight hill with a car about 6inches from your back so a auto trans would be a good thing.
Gas mileage might be a little better with the manual.
Coolou
Received 1,675 Likes
For a DD the A4 should be great for you!
I have found that most folks seem to want the auto trans and order it for their new ride.
Coolou
Coolou
Yeah man, if it's just a DD then I would go for the auto. I don't know about you but when I get into a musclecar with a manual I can't keep my foot out of it. Therefore costing me more in gas and probably some unecessary repairs down the road.
A4 trans is slugish from stock tune. You will see huge improvements with a tune. Add a 3:42 gear and a stall and you will beat the pants off of m6 vetts with same mods I love my auto
Coolou
Coolou
http://www.tim-yvonne.com/mikemercury/342.htm
http://www.tim-yvonne.com/mikemercury/ratio.htm
^ Thanks.. interesting
I have one more question for yall its off topic but i dont wanna start a new thread for it... i did some searching but couldnt really find it... so my dad is telling me that these vettes are made of fiberglass and if you drive them in snow or whatever they crack REALLY easy? is that true... thanks
No, the cars don't crack easy, your Dad is a relic, like mine, from the past. He probably things that our cars are pigs on gas too, ask him.
I bought my C5 knowing it was going to be my DD and I had to have the A4/Automatic. I have not regretted it once so far.
They are actually a composite material. This material is light and very strong. GM designed the Vette, as it does all cars, to be a year around vehicle. It's a lot less likely to crack in cold weather than a metal car is to rust. Your Dad needs to learn a bit more about modern materials before dispensing faults information
I know my dad believes all Ford cars break down all the time and that FORD stands for Fix Or Repair Daily or Found On Road Dead.
Not to mention that Ford originally wanted to name the car Rustang because it rusted so much but they settled on giving it the horse-name instead, Dad's . . .
You will be suprised how well the A4 works, especially with the performance 3.15 rear end in it (that is the GM performance rear - the code is G92 in the drivers rear compartment lid)
Then if you put the 3.42's in it from a MN6 Vette you'll be flying and still getting the same MPG (I have a chart showing the diff in RPM's at different MPH) let me know if you want a shot of the chart
Thanks,matt
GMC pick-up does not equate to a Corvette for clutch life.
OK so enlighten me with your facts. with everything being relative a clutch is matched to the car. If one in a Vette is being hammered due to racing or a bad operator you are right it does not equate. So tell me why they don't last in a Vette.
Thanks,matt[/QUOTE]
Hey Matt, could I get that chart?
Hart-Rowe@att.net
Thanks,
Scott
Thanks,matt[/QUOTE]
Hart-Rowe@att.net
Thanks,
Scott
C5 body panels are made out of SMC; which is not "fiberglass" -technically- but similar. I believe the Corvette started using SMC body panels in 1984.
http://en.wikipedia.org/wiki/Sheet_moulding_compound
