removal of front turn signal lens, how?
Received 2,680 Likes
2018 C5 of Year Finalist
If you're referring to the actual corner light housings, you have two options...
1) You can access the corners from underneath the car and removing the corner spoiler and back access panel in the wheel well.
or
2) If you are planning other mods, like HID lights, new fogs, etc., you can access the corner light housing from the top after you remove the stock lights. This is much easier than going in from underneath, however I would only recommend it if you're performing more than one mod. If it's just the corners, go in from underneath although it a little tougher on the back...
or
They are spring clipped into the fascia from the back side-if you push on them you'll feel the springs. You'll either have to get them from underneath or take the fascia off/loose (not a very tough job either).
check the C5 Tech DIY sticky..it is the first topic I even have pictures posted
pewter99s instructions are great
This might help too
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
This might help too
Document ID# 655625
Removal Procedure
Notice
Tighten
Tighten
FreedomFighter (09-13-2016)
I never understood the need for the tension spring either. Why didn't the GM engineers simply use a 3rd screw? You can feel the tension that the spring produces, so perhaps it was to help with road bumps/shocks, etc.
Possibly but again with the 2 screws already intact it doesn't move at all. I just assume it was on someones to do list and brag sheet at the end of the year. I question alot of things that GM did on our cars .
I think it was put there to make re-assembly a pain in the ***
