Need a 2004 C5 low speed cooling fan schematic.
Hi,
I need a 2004 C5 low speed cooling fan wiring schematic. The one in the under hood relay/fuse box. The 04 is different from earlier yrs. I have a 02 schematic and it is different.
Thanks in advance!
Thanks in advance!
Here 8vett7, save this to your collection, ok
'04 Cooling Fans
EDIT---I'm looking at '02 and '04 Schematics, and I don't see any difference. am I missing something?
'04 Cooling Fans
was plugged in with the notch facing forward. So something in the wiring is different.
We rotated it both ways and it blew the fuse both times. Confusing!
Thats why I wanted a 04 diagram.
Here is a link showing the two different fuse box orientations of the relay.
http://www.saccitycorvette.com/Befor...-COOL-IT-.html
So which one does the '04 have, cut corner to the front or rear?
Edit----You can turn the factory installed relay either way, and it will still work. If in '04, the wireing to Terminals G2 and E2, under the bottom of the Fuse Block is reversed, and you are installing a modified relay, then you are now grounding the terminal that goes directly to the Fuse #49. POOF!!!
If you don't get it working you might want to check out this thread for more ideas.
http://forums.corvetteforum.com/c5-t...itch-idea.html
