Can worn tires cause the ABS and traction control check lights to come on?
Today i was driving a steady 60 and the check lights came on Can worn tires cause the ABS and traction control lights to come on?
What tire sizes (front and rear) do you have mounted?
Pull the codes and post them.
Yes, especially if you were pushing the ratio. Happened to me. I was fine for two yrs but as it wore those lights came on. I was close when they were new so I expected it, but if you have stock size tires it won't happen, thats another issue.
