key fob
Stand by the driver's side rear fender (where the receiver is) and press the lock and unlock buttons on the fob until the horn blows. That's all there is to it.
Received 19,293 Likes
'20-'21-'22-'23-'24
You can download an electronic version of the manual from here: www.gmpartshouse.com
Here is the procedure:
Put the key in the ignition and turn to on position (do not start the car). On the dash hit the options button until it cycles to a blank screen. Hold down the reset button on the dash four seconds and you will see"FOB Training" on the DIC. Press the reset button again and it will ask you to hold the LOCK and UNLOCK together. The car will beep after a few seconds.
Then the DIC will ask you to program the 2nd FOB. If you have one, the hold down the LOCK & Unlock on that one until it beeps. Then it will ask you if you have a 3rd. If you do, then do the same - if not, the hit any other button on the dash cause you are done.
