Window tint removal
Window tint removal
The window tint in my 2002 was starting to peel at the corners of the windows so I decided it was time to get rid of it. When I peeled it off it left a layer of tint on the window that is extremely hard to get off even with a single edge razor and straight amonia. Is there a trick to removing this film?
Loosen the edges with a new razor and try and peal off as much as you can then, scrape with a fresh razor with a soap and water mix, when you get near the bottom of the window tuck the bottom molding down so you can get all the glue from the bottom of the window. Be carefull it's easy to slip with a soapy razor, and you might want to have a towel at the bottom of the window you will have a lot of water running down the window onto the door.
Split open a large garbage bag, lay it under the window and soak it with Windex type spray. Put the garbage bag to the window so it sticks. Let it sit for a bit and repeat, then it should peel off.
I just did this last weekend on my side windows,so I know it works:
NOTE:you're going to want to keep the open flames to a minimum during this operation...
With a single edge razor blade,get one corner of the tint loose so you can grab it,then just slowly pull the tint film off the glass.
A lot of the tint adhesive is going to come off with the tint,but there'll still be plenty left on the glass-not to worry...
Get a can of Lacquer thinner,soak a rag with it(not so soaked that it drips down the inside door panel,and keep it OFF your paint) and start wiping the adhesive off(you're going to have to rub a little on the first pass)-keep enough thinner on the rag that it doesn't try to "stick" to the glass,but don't slop it all over the place,either.
You'll soon have goo smeared all over the glass,so you do the same thing again,with a second,clean,lacquer thinner soaked rag.(the thinner won't hurt the rubber "scraper" on the inside at the bottom of the glass)
Now there's still goo,but not so much.
Do it again,and you should pretty much have it all off.
Now go over the glass one more time with a clean rag DAMPENED with Lacquer thinner.
The glass should be nice and clean now,but you're still going to want to clean it with your favorite glass cleaner,and then you're done-takes about ten minutes per side.
If you do happen to drip some on the door panel,a shot of Meguiars Leather Conditioner,or 303 Protectant (great stuff!) will put it back the way it was.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
DO NOT use Laquer thinner on anything or anything on your car. It will cause any plastic or rubber to become a gooey mess, if you have leather intereior it will ruin the door cards, and if you get any on the paint it will remove it as well. When The girl stripped my window tint, she took a 4X5 sheet of heavy brown paper (Just like an old supermarket brown paper bag cut open, and slipped it down between the glass and the rubber window seal to protect the door cards or panels.
Verrry effective on a hot summer day. I've seen it done. All the glue and crap comes right off. For the sides, razor blade and a little time+cursing.
I used the garbage bags on the side too. Neighbors laughed at the sight of black trash bags hanging out all ends of the door. But tint fell right off.
