Turn signals not working bulbs pop? Step inside (pics)
changed my turn signals and this is how they ended up . TOSTED! and the end result of new corners I hope they do not burn like the stock ones
Common problem. Your running lights have melted holes in your plastic light housing. Now water will get in when you wash your car or drive in the rain, the water breaks your hot bulbs.
People have fixed this by using aluminum foil tape and epoxy to seal the holes. Also windshield sealant has been use to seal really small holes.
Good luck !
BTW, nice car and beautiful garage!
Good luck !
Looks like new lamp units are needed. I inhibited my DRLs and I've never had that problem.
Pulling the A2 fuse is the easiest.
Thanks and Yup stock ones where burned got the clears on it now from depo
Good luck !
Good luck !
1 Post
Don't wait to see if the new housing will burn through... if they're plastic... they will!
All directional signals and running lights work properly. The only thing I lost was the beep and lights flashing when I activate the key fob lock so, I stand close to hear the locks clicking closed.
Activating the key fob-unlocking feature will see all of the parking / running and interior lights activate for entry.
Although I liked the DRL idea I didn't like having to replace burned housings so, I run with my running / parking lights on during the day.
Nice looking garage!
Semper Fi!
Huurraah!
Bob
