Grinding noise from the rear when hitting a bump?
Looking for some of your insights - recently driving on the freeway when a chunk of highway (about 6" X 6" X 8") was before me before I could get around it - hit the bottom of the front driver's side fender and cracked a little and went over it with rear driver wheel - bent the wheel! Put on a new wheel, but now when I hit even a small bump on the road they will be a clunk in the driver's rear - and sometimes it is a grinding noise - but very quick. I have been underneath the car a dozen times looking for marks, loose bolts, scrape marks, etc - nothing. Could this be the half shaft damaged from hitting the chunk? Anyway to check or verify - I have even looked at the axles while the car was on blocks and the engine on and in drive. Looking for advice before I go into the dealer. Thanks.
It sounds like something similar to what I had-
it turned out to be the emergency brake shoe on the rear rotor! If it is loose or one of the spring/rods are out of position it will cause the sound when a bump is hit!
You will need to get a replacement shoe for the e-brake (best to do both sides) and install it
Thanks,Matt
Thanks,Matt
Thanks,Matt
Thanks,Matt
