Convertible rear tub removal
Old 10-27-2015, 04:50 PM
Sam Handwich
Sam Handwich's Avatar
Originally Posted by David McDaniel
BrentA hi,I have a c6corvette coupe&I need instructions on how to remove the rear tub&type/brand of glue I need to install new tub.Will greatly appreciate!
I think 3M will have just about any product you would need in the way of adhesives, sealants, etc. There may be some other good brands, but I have such good results with 3M that is the first stop for me.
Old 10-27-2015, 04:56 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
I used 3M 5200 when I did mine.
http://www.jamestowndistributors.com...ct.do?pid=2002
Its a polyurethane compound and does a great job sealing up leake in joints.
Old 10-27-2015, 05:07 PM
Sam Handwich
Actually, 3M 5200 is a urethane compound (according to everything I have ever seen). Not sure why they leave out the "poly". But if you go that route be aware of a couple of things:
1. they make a fast cure and a slow cure version
2. they make it in black, and white
3. it is recommended for through the hull fittings on boats; it might look like caulk, but it is a lot more money because it is a much better product
good luck
Old 10-27-2015, 06:56 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Thanks for posting the details Sam.
It's a much better product than what they use at the factory. When I converted my C5 Coupe to a FRC widebody I used it to redo the rear tub as well as the roof.
A lot of the C5 fixed roof coupes develop leaks on the top deck and sides as GM uses a very stiff glue at the factory, however after a period of time the seams where they glued them crack due to stress and flex in the body, which creates all the leaks that everyone seems to have after they get some miles on their vettes.
I'm not sure what they do with C7's.
good luck
Quick Reply: Convertible rear tub removal
