Cold Air Intake
Cold Air Intake
Does anyone have any knowledge about BCP's cold air intake or have you purchased on and find yourself satisfied or un-satisfied../
I found it on the auction site..
http://cgi.ebay.com/ebaymotors/BCP-0...item20b55cd194
There are better options. The dual cone set up is not a true cold air setup in that it still takes air from inside the engine compartment. The Callaway Honker and the Vararam are better options since they are true cold air intakes. The Callaway is a very high quality product and looks excellent. The vararam is inexpensive and not the best looking thing on the planet but they work well.
Received 1,674 Likes
Just get a Blackwing and be done with it! You can find them used worth the money right here on this forum. Buy it, clean it and install it.
Honestly I am not looking for more power....you seldom gain that much...even with the cold air set up and aftermarket exhaust...I just LIKE the look of the air cleaner setup
Cruise-In VIII Veteran
St. Jude Donor '07
Get a VARARAM. Takes air from outside of the car. Better throttle response and the punch at WOT when at HIGHWAY speeds is unmatched by a CAI.
True RAM AIR.
True RAM AIR.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
St. Jude Donor '12-'13-'14-'15-'16
I have the Breathless Performance C.A.I. it is a true cold air very pleased with it. Good match for the long tube hedders, x pipe and Corsa Exhaust.
Received 19,276 Likes
'20-'21-'22-'23-'24
It's what I've run on my last two C5s and it works well. I will admit it doesn't have as much power potential as the Vararam, but it is very easy to install and looks good under the hood.
Those dual cone intakes are garbage, IMHO. The big problem with them is their merge design. They cause a lot of turbulence. And regardless of how large the "T" pipe size is, you're not going to get twice that amount of air into the merge bar, so it makes the air slow down as it's being sucked in (like a traffic jam). While they are still better than stock, you're better off with the zip-tie mod over those dual cone intakes.
I've had these both and they're both great products. In my opinion, they're yin and yang to each other though. One has a better build quality, while the other works far better.
The BPP is called the "Vortex Rammer" which is pretty good, but it's a total pain in the butt to clean the filter. If you get the see-through cover, that's a pain in the butt to clean as well. However, it certainly made a big difference over stock. Although, I had to clean it once every month because bugs would start to accumulate on the inside of the cover.
The Vararam is a great intake too. Some will tell you the fit-n-finish on it sucks. I won't argue with that. But I will argue that it's likely the best intake for a C5. Others have said they don't think it actually works, but every Vararam owner will tell you otherwise. I won't claim any HP gains, but I can tell you that I could burn out on the freeway with a stock car on T1Rs at 50MPH after installing the Vararam.
many guys have also taken the V-ram off do the turbulence and used duct tape over the fog light screens for better aerodynamics.
1/4 miles guys wont see much if any difference with the screens duct taped or closed off, but any road racing or road track days, there is a big difference.
If you believe 13 RWHP is not that much for the money spent, try pricing out other performance-enhancing mods!
Now with those mods pricing out at roughly $0 (to me), that's REAL bang-for-the-buck!!!
I believe the Vararam is the best performing CAI you can buy, but it often will make your computer throw a lean code from time to time, if you don't get your car retuned. It's really just a nuisance, and you can reset the CEL, but some guys think the light means they blew up their motor.
St. Jude Donor '07
I do agree, the VR is the best one of the bunch!!!
I believe adding a tune might gain even a bit more. I did not do a "before-after" test on the same car, but when I was test-driving C5's, the one I eventually bought seemed noticeably quicker than stock or catback-only C5's I tested. The prior owner had paid a shop to install a Corsa Pace Car catback and Callaway Honker intake, plus a tune.
Most of us are very tired of this question,,,,but being a newbie myself on this question a few years ago,,,,CAI is CAI! The VRB2 is the best true CAI on the market for the C5 without any other mods required. For those who have never had one on their C5,,,,they don't make the CF friendly smiley for me to select and insert here.
I personally know of a half a dozen C5's that picked up .2 to .3 seconds in the 1/4 with NO OTHER CHANGES!
At speeds above 50 mph,,,,the VRB2 sells itself. Some look or fit better, but none out perform this simple, yet effective air intake.
OP, If you don't care about performance increases, buy any of the more expensive or cheaper options that you like the look of. As they say, it is your car, and we are all cool with that!
You have to remember to remove the Halltech honeycomb if you install a Supercharger. I sucked mine into the MAF on the dyno, because of the added pressure. It ended up looking like a Pringle, but I got lucky that it didn't damage the sensor.
I didn't like the factory airbox and mess so I installed a Blackwing. I just wanted something clean looking and maybe flowed a lil better.
Not a big fan of the dual cone chrome intakes, but if you like it's look then you should get it.
Received 2,675 Likes
2018 C5 of Year Finalist
I helped a friend install the Vararam unit and although I understand in concept what it accomplishes, the install was a real PITA and I was not impressed with the fit/finish of the system. Some, as mentioned, love it so to each his own.
To the OP on the dual cone intake, IMO their redeeming quality is show looks. I know you're not looking for performance, however I would still look around as the finish on some of the cheaper systems are pretty bad. I was at a show a few weeks ago and saw a really nice chrome twin cone system that looked great with the other engine dress up components the owner had and then I saw a twin cone system that had a poor SS finish, ugly center weld, etc.
Good luck!
